Amazon Fire HD 3rd Gen Disassembly
    1. Amazon Fire HD 3rd Gen Disassembly, Pry off the plastic back.: step 1, image 1 of 3 Amazon Fire HD 3rd Gen Disassembly, Pry off the plastic back.: step 1, image 2 of 3 Amazon Fire HD 3rd Gen Disassembly, Pry off the plastic back.: step 1, image 3 of 3
      • Using a Jimmy, start at the volume control and work your way around by prying off the back and then lifting it back like a book.
      Ask FixBot
    2. Amazon Fire HD 3rd Gen Disassembly, Peeling off the tape.: step 2, image 1 of 3 Amazon Fire HD 3rd Gen Disassembly, Peeling off the tape.: step 2, image 2 of 3 Amazon Fire HD 3rd Gen Disassembly, Peeling off the tape.: step 2, image 3 of 3
      • Peel off the 2 yellow pieces of yellow tape on the battery.
      Ask FixBot
    3. Amazon Fire HD 3rd Gen Disassembly, Disconnect the ribbon cables: step 3, image 1 of 3 Amazon Fire HD 3rd Gen Disassembly, Disconnect the ribbon cables: step 3, image 2 of 3 Amazon Fire HD 3rd Gen Disassembly, Disconnect the ribbon cables: step 3, image 3 of 3
      • Take off all the ribbon cables connected to the main board. (Marked in Red)
      • On the 2 speakers marked in yellow, be sure to pull straight up. Then unclip the speaker cables.
      Ask FixBot
    4. Amazon Fire HD 3rd Gen Disassembly, Unscrew speakers and gray bracket: step 4, image 1 of 1
      • Using a T4 Torx driver, unscrew each of the 2 screws holding in the 2 speakers. (red)
      • Then, take out the 7 screws hold in the gray bracket (yellow)
      • Now, unscrew the 8 screws holding the motherboard. (green)
      Ask FixBot
    5. Amazon Fire HD 3rd Gen Disassembly, Unscrew the I/O: step 5, image 1 of 1
      • Next, use a T4 Torx Screwdriver again to unscrew the headphone jack and the Micro USB port.
      Ask FixBot
    6. Amazon Fire HD 3rd Gen Disassembly, Take everything out.: step 6, image 1 of 1
      • 1. Remove the Headphone and USB ports.
      • 2. Remove motherboard.
      • 3. Remove the speakers.
      • 4. Remove gray bracket with battery.
      Ask FixBot
    7. Amazon Fire HD 3rd Gen Disassembly, Remove the screen.: step 7, image 1 of 1
      • Now, using a T4, unscrew the 4 screws holding in the screen.
      Ask FixBot
    8. Amazon Fire HD 3rd Gen Disassembly, Your Done!: step 8, image 1 of 1
      • Congrats! Now follow the directions in reverse to reassemble your Fire!
      Ask FixBot
Finish Line
4 other people completed this guide.
Cooper Anderson
571 Reputation
2 Guides authored
1 Guide Comment
Please where can I get the digitizer?
Mine is shattered and I haven't used it for over 3years but I can still power it up.
Will very much appreciate a lead.
Patrick,
Nigeria
Patrick Mordi - Reply Share
Past 24 Hours: 3
Past 7 Days: 21
Past 30 Days: 118
All Time: 2,388
