Up to 20% off select tools
Amazon Fire HD 10 Screen Replacement
Views: 41K
View statistics:
Past 24 Hours:
10
Past 7 Days:
48
Past 30 Days:
194
All Time:
40,933
Comments: 22
5 comments on steps, 17 guide comments.
Go to guide comments
Completed: 27
27 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Before you begin, make sure the device is off. The screen and digitizer will come off as one connected component.
    1. Amazon Fire HD 10 Screen Replacement, Screen: step 1, image 1 of 3 Amazon Fire HD 10 Screen Replacement, Screen: step 1, image 2 of 3 Amazon Fire HD 10 Screen Replacement, Screen: step 1, image 3 of 3
      • Avoid prying near bottom right hand side due to LCD Connector
      • Use a plastic opening tool to pry the screen up in the right hand corner.
      Ask FixBot
    2. Amazon Fire HD 10 Screen Replacement: step 2, image 1 of 1
      • Do not completely remove the screen yet as there is a ZIF connector connected.
      • Lift the screen and digitizer from the case.
      • You may need to use some force due to the glue.
      Ask FixBot
    3. Amazon Fire HD 10 Screen Replacement: step 3, image 1 of 2 Amazon Fire HD 10 Screen Replacement: step 3, image 2 of 2
      • Be mindful of the ZIF connector.
      • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
      Ask FixBot
    4. Amazon Fire HD 10 Screen Replacement: step 4, image 1 of 1
      • Remove the screen and digitizer from the case completely.
      Ask FixBot
27 other people completed this guide.
Author
with
Jaie Hillery
1,774 Reputation
10 Guides authored
USF Tampa, Team 16-6, Blackwell Winter 2016 Member of USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 Members
120 Guides authored
17 Guide Comments
Where can you get a replacement digitizer screen? My grandson dropped his a couple days ago & I don't want to spend another $200 for a new one.
misterh - Reply Share
I am seeing replacement screen/digitizers for these now on ebay. With a little searching around I found one direct ship from Hong Kong for $70US. Good Luck!
Greg Charland - Reply Share
I can't seem the find a replacement screen for this specification anywhere
Stephanie Eyime - Reply Share
I need the the cable that goes to the sceen. As i changed out my battery, when i tried to carefully remove the zif connector, it broke off. Woe is me.
boumpanimusic - Reply Share
What is needed to attach the screen back to the case?
Jimmy Lee - Reply Share
Past 24 Hours: 10
Past 7 Days: 48
Past 30 Days: 194
All Time: 40,933
