Amazon Fire HD 10 Front Facing Camera Replacement
    1. Amazon Fire HD 10 Front Facing Camera Replacement, Screen: step 1, image 1 of 3 Amazon Fire HD 10 Front Facing Camera Replacement, Screen: step 1, image 2 of 3 Amazon Fire HD 10 Front Facing Camera Replacement, Screen: step 1, image 3 of 3
      • Avoid prying near bottom right hand side due to LCD Connector
      • Use a plastic opening tool to pry the screen up in the right hand corner.
      Ask FixBot
    2. Amazon Fire HD 10 Front Facing Camera Replacement: step 2, image 1 of 1
      • Do not completely remove the screen yet as there is a ZIF connector connected.
      • Lift the screen and digitizer from the case.
      • You may need to use some force due to the glue.
      Ask FixBot
    3. Amazon Fire HD 10 Front Facing Camera Replacement: step 3, image 1 of 2 Amazon Fire HD 10 Front Facing Camera Replacement: step 3, image 2 of 2
      • Be mindful of the ZIF connector.
      • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
      Ask FixBot
    4. Amazon Fire HD 10 Front Facing Camera Replacement: step 4, image 1 of 1
      • Remove the screen and digitizer from the case completely.
      Ask FixBot
    1. Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: step 5, image 1 of 3 Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: step 5, image 2 of 3 Amazon Fire HD 10 Front Facing Camera Replacement, Front Facing Camera: step 5, image 3 of 3
      • Remove the two screws from front facing camera using the T5 Torx Screwdriver.
      • Make sure you place the screws in a safe location nearby.
      Ask FixBot
    2. Amazon Fire HD 10 Front Facing Camera Replacement: step 6, image 1 of 2 Amazon Fire HD 10 Front Facing Camera Replacement: step 6, image 2 of 2
      • Lift the black plastic cover once the screws are removed.
      • Place aside for later reassembly.
      Ask FixBot
    3. Amazon Fire HD 10 Front Facing Camera Replacement: step 7, image 1 of 2 Amazon Fire HD 10 Front Facing Camera Replacement: step 7, image 2 of 2
      • Detach the connector using a plastic opening tool or spudger.
      • The camera is still connected to the motherboard.
      Ask FixBot
    4. Amazon Fire HD 10 Front Facing Camera Replacement: step 8, image 1 of 2 Amazon Fire HD 10 Front Facing Camera Replacement: step 8, image 2 of 2
      • Grip the camera and lift up to detach the ZIF connector from the motherboard.
      Ask FixBot
Jaie Hillery
1,774 Reputation
10 Guides authored
USF Tampa, Team 16-6, Blackwell Winter 2016 Member of USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 Members
120 Guides authored
1 Guide Comment
Can this camera module be upgraded with a better version?
Jimmy Kee - Reply Share
Past 24 Hours: 2
Past 7 Days: 28
Past 30 Days: 107
All Time: 1,802
