Up to 20% off select tools
Amazon Fire HD 10 Battery Replacement
Views: 54K
View statistics:
Past 24 Hours:
13
Past 7 Days:
78
Past 30 Days:
318
All Time:
53,639
Comments: 17
8 comments on steps, 9 guide comments.
Go to guide comments
Completed: 11
11 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 30 minutes
Difficulty: Moderate
Parts
Tools
  • iFixit Opening Tool
    4.8
  • Spudger
    4.9
Introduction
Go to step 1 ↓
Before you begin, make sure the device is off. You will need to use the screen replacement guide as a prerequisite.
    1. Amazon Fire HD 10 Battery Replacement, Screen: step 1, image 1 of 3 Amazon Fire HD 10 Battery Replacement, Screen: step 1, image 2 of 3 Amazon Fire HD 10 Battery Replacement, Screen: step 1, image 3 of 3
      • Avoid prying near bottom right hand side due to LCD Connector
      • Use a plastic opening tool to pry the screen up in the right hand corner.
      Ask FixBot
    2. Amazon Fire HD 10 Battery Replacement: step 2, image 1 of 1
      • Do not completely remove the screen yet as there is a ZIF connector connected.
      • Lift the screen and digitizer from the case.
      • You may need to use some force due to the glue.
      Ask FixBot
    3. Amazon Fire HD 10 Battery Replacement: step 3, image 1 of 2 Amazon Fire HD 10 Battery Replacement: step 3, image 2 of 2
      • Be mindful of the ZIF connector.
      • Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
      Ask FixBot
    4. Amazon Fire HD 10 Battery Replacement: step 4, image 1 of 1
      • Remove the screen and digitizer from the case completely.
      Ask FixBot
    1. Amazon Fire HD 10 Battery Replacement, Battery: step 5, image 1 of 3 Amazon Fire HD 10 Battery Replacement, Battery: step 5, image 2 of 3 Amazon Fire HD 10 Battery Replacement, Battery: step 5, image 3 of 3
      • Locate the power cable that links the battery to the motherboard.
      • Carefully unplug the battery power cable to disconnect the battery from the motherboard.
      • The third image shows what it should look like with the battery power cable is disconnected.
      Ask FixBot
    2. Amazon Fire HD 10 Battery Replacement: step 6, image 1 of 3 Amazon Fire HD 10 Battery Replacement: step 6, image 2 of 3 Amazon Fire HD 10 Battery Replacement: step 6, image 3 of 3
      • Begin by locating the double sided pull tape locations.
      • Do not lift on the battery when doing the following step. You will bend it. It is very pliable.
      • Pull the black soft tabs to release the tape's adhesion.
      • Make sure you pull the tabs slowly and continuously away from the case until the adhesive is completely out.
      • Do this to all 4 tabs until the battery is completely free of adhesion to the device's backing.
      Ask FixBot
    3. Amazon Fire HD 10 Battery Replacement: step 7, image 1 of 3 Amazon Fire HD 10 Battery Replacement: step 7, image 2 of 3 Amazon Fire HD 10 Battery Replacement: step 7, image 3 of 3
      • Make sure all the adhesive is removed before trying to lift the battery from the case.
      • After the battery is totally free of any adhesion, simply lift the battery from the case.
      Ask FixBot
    4. Amazon Fire HD 10 Battery Replacement: step 8, image 1 of 3 Amazon Fire HD 10 Battery Replacement: step 8, image 2 of 3 Amazon Fire HD 10 Battery Replacement: step 8, image 3 of 3
      • Inspect battery for any leakage.
      • Please follow all U.S. regulations and laws when disposing or recycling the battery.
      Ask FixBot
11 other people completed this guide.
Author
with
Jaie Hillery
1,774 Reputation
10 Guides authored
USF Tampa, Team 16-6, Blackwell Winter 2016 Member of USF Tampa, Team 16-6, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G6
3 Members
120 Guides authored
9 Guide Comments
why is there so much empty space next to the battery?
echow2001 - Reply Share
Big screen, little processor. The screen dictates the space, that’s why the battery has to be secured with adhesive.
ctgblue - Reply Share
I’m confused. If it’s a battery replacement issue, why is the battery not listed on the parts list? Is that not necessary once you take the old one out? Where do I get a new battery to replace the one this is teaching me to remove? O.o
tyger.night - Reply Share
You’ll have to google one. Amazon does not offer one. They want to sell you a new Kindle instead.
I am buying one with the plastic tools (ebay), even if they suck, they should get through this process once.
How do you know if ita battery or charging port? Mine dont do anything whe. Its
Tech Reviews - Reply Share
Past 24 Hours: 13
Past 7 Days: 78
Past 30 Days: 318
All Time: 53,639
