Up to 20% off select tools
Amazon Fire Game Controller Motherboard Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
67
All Time:
1,144
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your motherboard on your Amazon Fire Game Controller has been damaged or needs replacement, this guide will aid you through the process. Motherboard replacement may be necessary if controller inputs are incorrect or no longer working, or if a liquid had been in contact with your controller. A motherboard ties the components of an electronic device together in one spot, allowing for smooth communication and functionality. Before using this guide to help you replace the motherboard in your Amazon Fire Game Controller, make sure that it is absolutely in need of replacement. Some signs of this could be incomplete functions of buttons and triggers, lagging, or completely not working at all. If any of these issues apply to your Amazon Fire Game Controller, then continue reading this guide on replacing the motherboard. Happy fixing!
    1. Amazon Fire Game Controller Motherboard Replacement, Motherboard: step 1, image 1 of 1
      • Use a Triangle #2 screwdriver to remove the six 10 mm screws from the back of the controller.
      Ask FixBot
    2. Amazon Fire Game Controller Motherboard Replacement: step 2, image 1 of 1
      • Pry the two shell pieces from one another from the top orientation with a plastic opening tool.
      • The weights will fall out.
      Ask FixBot
    3. Amazon Fire Game Controller Motherboard Replacement: step 3, image 1 of 1
      • Disconnect the battery terminal wires and the play, pause, and stop wires from the motherboard.
      Ask FixBot
    4. Amazon Fire Game Controller Motherboard Replacement: step 4, image 1 of 1
      • Use a J1 screwdriver to unscrew the four 7 mm screws from the motherboard.
      Ask FixBot
    5. Amazon Fire Game Controller Motherboard Replacement: step 5, image 1 of 1
      • Lift the motherboard out of the controller casing.
      Ask FixBot
2 other people completed this guide.
Author
with
Andrew Klopfenstein
55 Reputation
2 Guides authored
IUPUI, Team S4-G4, Wilson Summer 2019 Member of IUPUI, Team S4-G4, Wilson Summer 2019
IUPUI-WILSON-SU19S4G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 67
All Time: 1,144
