Amazon Fire 5th Generation Speaker Replacement
    1. Amazon Fire 5th Generation Speaker Replacement, Speaker: step 1, image 1 of 2 Amazon Fire 5th Generation Speaker Replacement, Speaker: step 1, image 2 of 2
      • Ensure that your device is turned off.
      • Remove any micro-SD card that may be installed in the Fire. Failure to do so could damage the micro-SD card itself or the micro-SD card reader on the Fire.
      • While holding the device firmly, wedge the iFixit Opening Tool into the crease along the outer edge of the device (as shown in the image).
      • Slowly, grind the iFixit Opening Tool into the crease along the outer edges of the device until the entire back cover loosens.
      • Then, remove the back cover from the device.
      Ask FixBot
    2. Amazon Fire 5th Generation Speaker Replacement: step 2, image 1 of 2 Amazon Fire 5th Generation Speaker Replacement: step 2, image 2 of 2
      • Pry the speaker from the case using the iFixit Opening Tool.
      • Lift the speaker up from the device to remove the speaker wires from their groove in the case.
      • Be careful not to pull the speaker wires from the motherboard.
      Ask FixBot
    3. Amazon Fire 5th Generation Speaker Replacement: step 3, image 1 of 3 Amazon Fire 5th Generation Speaker Replacement: step 3, image 2 of 3 Amazon Fire 5th Generation Speaker Replacement: step 3, image 3 of 3
      Ask FixBot
Amber Bunch
1,405 Reputation
3 Guides authored
USF Tampa, Team 1-2, Nance Spring 2016 Member of USF Tampa, Team 1-2, Nance Spring 2016
USFT-NANCE-S16S1G2
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 31
Past 30 Days: 108
All Time: 1,958
