Amazon Echo Studio Power Supply Board Replacement
    1. Amazon Echo Studio Power Supply Board Replacement, Power Supply Board: step 1, image 1 of 3 Amazon Echo Studio Power Supply Board Replacement, Power Supply Board: step 1, image 2 of 3 Amazon Echo Studio Power Supply Board Replacement, Power Supply Board: step 1, image 3 of 3
      • Flip the device upside down.
      • Pry up the edge of the rubber base panel with a spudger, then pull the rest of it off by hand.
      Ask FixBot
    2. Amazon Echo Studio Power Supply Board Replacement: step 2, image 1 of 3 Amazon Echo Studio Power Supply Board Replacement: step 2, image 2 of 3 Amazon Echo Studio Power Supply Board Replacement: step 2, image 3 of 3
      • Use a T15 Torx screwdriver to remove the nine 3.2 mm screws.
      • Use a Torx T10 screwdriver to remove the six 2.7 mm screws.
      • After removing the screws, gently lift the base off, with care not to damage any of the connected cables.
      Ask FixBot
    3. Amazon Echo Studio Power Supply Board Replacement: step 3, image 1 of 3 Amazon Echo Studio Power Supply Board Replacement: step 3, image 2 of 3 Amazon Echo Studio Power Supply Board Replacement: step 3, image 3 of 3
      • Before fully removing the base, remove the three attached connectors.
      Ask FixBot
    4. Amazon Echo Studio Power Supply Board Replacement: step 4, image 1 of 2 Amazon Echo Studio Power Supply Board Replacement: step 4, image 2 of 2
      • Now unscrew the the single 10 mm Phillips screw.
      • Remove the power supply board.
      Ask FixBot
2 other people completed this guide.
Nick Saranich
297 Reputation
2 Guides authored
UMass Dartmouth, Team 2-6, Petersen Fall 2022 Member of UMass Dartmouth, Team 2-6, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G6
4 Members
72 Guides authored
16 Guide Comments
Thank you for this guide. It was very easy operation, but I believe problem with Echo is that its impossible to get spare parts?
My Echo Studio is in short circuit state.
https://ibb.co/kqTXw0w
https://ibb.co/zV4KH6y
https://ibb.co/GMgPDDY
https://ibb.co/4PMZjDj
https://ibb.co/k0MsFPM
Kertalaaki - Reply Share
Taking this thing apart really is easy. Thanks for the tip on how to get started. But as Kertalaaki figured, it seems there is no chance to get replacement parts. I guess Amazon prefers to sell new devices instead of having people repair their Studio device. I have a similar problem Kertalaaki describes. Whenever I plug the device in, it causes the breaker to blow. Now having the device in hand, I can't see any obvious damage as Kertalaakis photos show, but I still would like to get me a new power supply board. If anyone has any ideas on how to get one, please share! Thanks a lot in advance!
Ingo Gambin - Reply Share
Same Problem like Ingo and Kertalaaki. Did anyone figure out how to get a new power supply?
Martin Dirr - Reply Share
I contacted the Amazon regarding the matter, and spare parts are not available. The solution from their side was a credit towards a new device with a discount. Spare parts are not available.
The power source is custom built just for this implementation and there is nothing similar on the market as far I have found.
Past 24 Hours: 4
Past 7 Days: 33
Past 30 Days: 130
All Time: 3,803
