Amazon Echo Studio Motherboard Replacement
Views: 2.6K
View statistics:
Past 24 Hours:
10
Past 7 Days:
34
Past 30 Days:
134
All Time:
2,595
Comments: 17
11 comments on steps, 6 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
The Echo Studio motherboard is located deep in the device, and other components must be extracted to reach the motherboard. Causes of a faulty motherboard include the device being dropped from a high distance, repeated button use, etc... If there are signs of a faulty motherboard, such as not carrying out proper functions, access the motherboard with this guide.
Tools
    1. Amazon Echo Studio Motherboard Replacement, Power Supply Board: step 1, image 1 of 3 Amazon Echo Studio Motherboard Replacement, Power Supply Board: step 1, image 2 of 3 Amazon Echo Studio Motherboard Replacement, Power Supply Board: step 1, image 3 of 3
      • Flip the device upside down.
      • Pry up the edge of the rubber base panel with a spudger, then pull the rest of it off by hand.
      Ask FixBot
    2. Amazon Echo Studio Motherboard Replacement: step 2, image 1 of 3 Amazon Echo Studio Motherboard Replacement: step 2, image 2 of 3 Amazon Echo Studio Motherboard Replacement: step 2, image 3 of 3
      • Use a T15 Torx screwdriver to remove the nine 3.2 mm screws.
      • Use a Torx T10 screwdriver to remove the six 2.7 mm screws.
      • After removing the screws, gently lift the base off, with care not to damage any of the connected cables.
      Ask FixBot
    3. Amazon Echo Studio Motherboard Replacement: step 3, image 1 of 3 Amazon Echo Studio Motherboard Replacement: step 3, image 2 of 3 Amazon Echo Studio Motherboard Replacement: step 3, image 3 of 3
      • Before fully removing the base, remove the three attached connectors.
      Ask FixBot
    4. Amazon Echo Studio Motherboard Replacement: step 4, image 1 of 2 Amazon Echo Studio Motherboard Replacement: step 4, image 2 of 2
      • Now unscrew the the single 10 mm Phillips screw.
      • Remove the power supply board.
      Ask FixBot
    1. Amazon Echo Studio Motherboard Replacement, Subwoofer: step 5, image 1 of 1
      • Remove the two screws located across from each other on the outside of the plastic ring shown.
      • Remove the plastic outer ring that hugs the inside of the edges of the device.
      • This may require you to use a soft prying tool to separate it from the outer shell.
      Ask FixBot
    2. Amazon Echo Studio Motherboard Replacement: step 6, image 1 of 3 Amazon Echo Studio Motherboard Replacement: step 6, image 2 of 3 Amazon Echo Studio Motherboard Replacement: step 6, image 3 of 3
      • Remove the two 2.7 mm screws with a T10 Torx screwdriver.
      • Once the screws are removed, take the power supply's baseplate out of the unit.
      • You may need to gently pry the subwoofer's air ports from the round slots In the side of the unit.
      Ask FixBot
    3. Amazon Echo Studio Motherboard Replacement: step 7, image 1 of 2 Amazon Echo Studio Motherboard Replacement: step 7, image 2 of 2
      • On the silver ring located on the outer edge of the plastic portion of the subwoofer, you will see four 2.7 mm screws. Use a Torx T10 screwdriver to remove them, in order to remove of the subwoofer.
      • Once the four screws have been removed, gently pull the subwoofer out as to not damage the wiring connecting the subwoofer to the main board inside the unit.
      • Follow the wires from the subwoofer to the main board and disconnect the connector attaching them.
      • Your subwoofer is now disconnected and ready to be replaced.
      Ask FixBot
    1. Amazon Echo Studio Motherboard Replacement, Motherboard: step 8, image 1 of 2 Amazon Echo Studio Motherboard Replacement, Motherboard: step 8, image 2 of 2
      • Remove the thirteen 9 mm Phillips #00 screws.
      • Some screws may be hidden by other components; simply hold them out of your way during screw removal.
      Ask FixBot
    2. Amazon Echo Studio Motherboard Replacement: step 9, image 1 of 1
      • Unfasten the Phillips 9mm screws, using the Phillips #00 Screwdriver.
      • There may be obstruction against some screws, which can be avoided by using a spudger or your hand.
      Ask FixBot
    3. Amazon Echo Studio Motherboard Replacement: step 10, image 1 of 3 Amazon Echo Studio Motherboard Replacement: step 10, image 2 of 3 Amazon Echo Studio Motherboard Replacement: step 10, image 3 of 3
      • After removing the screws, locate the four power connectors on the motherboard and detach them from the motherboard.
      Ask FixBot
    4. Amazon Echo Studio Motherboard Replacement: step 11, image 1 of 1
      • Remove the motherboard from the device by pulling it out.
      • Be careful to not damage any of the loose wires inside the case while removing the motherboard.
      Ask FixBot
Colin Nicoll
109 Reputation
1 Guide authored
UMass Dartmouth, Team 2-6, Petersen Fall 2022 Member of UMass Dartmouth, Team 2-6, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G6
4 Members
72 Guides authored
6 Guide Comments
where can I buy a motherboard replacement ?
Juan Daniel Hernandez R - Reply Share
I also would like to know where to get a motherboard... my studio is stuck at the green ring.
Ed Wilcox - Reply Share
i also would like to know. mine stuck with cyan circle
Алексей - Reply Share
Is there any place to buy the Amazon Echo Studio Motherboard?
DOCA - Reply Share
hi is there a place to buy this motherboard?
Bede Bede - Reply Share
Past 24 Hours: 10
Past 7 Days: 34
Past 30 Days: 134
All Time: 2,595
