Up to 20% off select tools
Amazon Echo Show Screen Replacement
Views: 16K
View statistics:
Past 24 Hours:
6
Past 7 Days:
53
Past 30 Days:
195
All Time:
16,253
Comments: 8
2 comments on steps, 6 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
If your Echo Show's screen does not respond or is cracked, you might need to follow this guide to replace it. Before starting, gather a iFixit opening tool. Remember to carefully use your hands to remove the screen, as applying too much pressure might damage the screen further.
    1. Amazon Echo Show Screen Replacement, Screen: step 1, image 1 of 3 Amazon Echo Show Screen Replacement, Screen: step 1, image 2 of 3 Amazon Echo Show Screen Replacement, Screen: step 1, image 3 of 3
      • Use the plastic opening tool to gently lift the plastic protector from screen.
      Ask FixBot
    2. Amazon Echo Show Screen Replacement: step 2, image 1 of 2 Amazon Echo Show Screen Replacement: step 2, image 2 of 2
      • Once the protector is lifted from screen, use the plastic opening tool to remove the actual screen from device, using an opening near the bottom left corner.
      • Once both parts are removed from the device, you can insert the new screen itself. Make sure that the digitizer cable of the new screen is placed within the recess when replacing the screen.
      • If necessary, use adhesive to more firmly secure the LCD or the protector screen to the rest of the device.
      Ask FixBot
Author
with
Christina Simone
576 Reputation
4 Guides authored
6 Guide Comments
Where do you dug replacement glass for
the echo show 5
gravytray - Reply Share
There is no glass replacement. I just got off the phone with Amazon Customer Support and they do not manufacture glass replacement pieces. In other words, if you break the glass you are out of luck. I've submitted feedback (via telephone customer support) for Amazon to begin producing replacement parts and urge you to do the same. Problem with being an early adapter is that what is normal protocol for business (in this case making replacement parts) is not yet developed.
Unfortunate since now I have a $230 awesome piece of tech that has a shattered screen. Customer service gave me $30 :/
djpinna - Reply Share
You REALLY should remind folks that the front screen is a digitizer and has a delicate ribbon cable coming off it about 1 1/2 inches from the left lower corner. If you use a pry tool there, you’ll slice the ribbon and ruin the digitizer. Don’t ask me how I know! I now have an Echo show with no touch screen capability. Lower left corner about an inch and a half toward the center. No glue there but if you slide a spudger along there, you’ll cut it for sure. Word to the wise……
n3tqv - Reply Share
Yes…. &&^&^$^ ribbon! Where do you get a digitizer. And a power and speaker supply
Ryan Anderson - Reply Share
Any info on the brand / model number for the digitizer assembly, and any info on how to drive it? I would like to replace the “brains” of my Echo Show 10 2nd Gen with something like a Raspberry Pi. (Not too concerned about Touch, Sound, Mic, though if it was possible to make those work, all the better. Really just need video.). TIA!
Jonathan Yankovich - Reply Share
Past 24 Hours: 6
Past 7 Days: 53
Past 30 Days: 195
All Time: 16,253
