Amazon Echo Show 8 3rd Gen Volume Buttons Replacement
    1. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement, Power Board: step 1, image 1 of 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement, Power Board: step 1, image 2 of 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement, Power Board: step 1, image 3 of 3
      • Use a prying tool to remove the rubber foot at the bottom.
      • It is secured with adhesive and will lift off with some gentle prying.
      • Use an opening pick to remove the screw cover.
      Ask FixBot
    2. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 2, image 1 of 2 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 2, image 2 of 2
      • Use a Torx TR8 screwdriver to remove the two 2 cm screws.
      Ask FixBot
    3. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 3, image 1 of 2 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 3, image 2 of 2
      • Insert a jimmy in the gap between the display and chassis.
      • Pry around the perimeter until the back case releases.
      • Be careful as to not damage the ribbon cable on the top left area of the screen.
      • Remove the back case.
      Ask FixBot
    4. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 4, image 1 of 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 4, image 2 of 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 4, image 3 of 3
      • Use a Torx TR6 screwdriver to remove the two 5 mm screws that secure the power board.
      • Carefully lift the board without straining the ribbon cable.
      • Using an opening tool, carefully flip up the black ZIF locking flap that secures the ribbon cable.
      • Disconnect the ribbon cable.
      Ask FixBot
    1. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement, Speakers: step 5, image 1 of 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement, Speakers: step 5, image 2 of 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement, Speakers: step 5, image 3 of 3
      • Gently tilt the shell towards the top of the device and disconnect the ribbon cable from the board on the case.
      • Don't tilt the cable too much as you can damage the ribbon or the connector.
      Ask FixBot
    2. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 6, image 1 of 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 6, image 2 of 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 6, image 3 of 3
      • Use a TR6 screwdriver to remove the six 7mm screws located around the speaker assembly.
      • Gently tilt the speaker assembly towards the ribbon cable.
      • The ribbon cable is fragile and can be damaged if moved any other way.
      • Flip open the black tab on the connector towards the cable and gently pull.
      • Don't use too much force pulling up on the tab, as it can break and the cable will no longer be properly connected.
      Ask FixBot
    3. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 7, image 1 of 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 7, image 2 of 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 7, image 3 of 3
      • Use a TR6 Torx screwdriver to remove the eight 9 mm screws holding the metal bracket.
      • Gently lift off the metal bracket.
      Ask FixBot
    4. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 8, image 1 of 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 8, image 2 of 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 8, image 3 of 3
      • Remove the 2 rubber stoppers.
      • Remove all 14 screws with a Phillips #1 screwdriver.
      Ask FixBot
    5. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 9, image 1 of 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 9, image 2 of 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 9, image 3 of 3
      • Use a Phillips #1 screwdriver to remove the four 1.3 cm screws holding down each driver.
      • Gently pull the plastic plate towards the antenna cable.
      • There is a small antenna cable that is easy to rip off the solder joint, so lift carefully.
      • There are 8 screws on the long side of the housing, but there is no driver behind it, so you don't need to remove them.
      Ask FixBot
    6. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 10, image 1 of 2 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 10, image 2 of 2
      • Pry the speakers from the housing with a spudger.
      • The speakers are connected to a spring-loaded pin connector which is attached to the black plastic using industrial hot glue, so while you can heat the glue to remove it, the plastic may melt and/or deform, so we wouldn't recommend it.
      Ask FixBot
    1. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement, Motherboard: step 11, image 1 of 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement, Motherboard: step 11, image 2 of 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement, Motherboard: step 11, image 3 of 3
      • Use an opening tool to flip up the black ZIF locking flap that secure the four ribbon cables.
      Ask FixBot
    2. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 12, image 1 of 2 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 12, image 2 of 2
      • Use angled tweezers to disconnect all the ribbon cables from their motherboard sockets.
      • The ribbon cables are fragile; pull with care.
      Ask FixBot
    3. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 13, image 1 of 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 13, image 2 of 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 13, image 3 of 3
      • Remove all 10 5 mm screws on the motherboard using a TR6 Torx screwdriver.
      Ask FixBot
    1. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement, Volume Buttons: step 14, image 1 of 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement, Volume Buttons: step 14, image 2 of 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement, Volume Buttons: step 14, image 3 of 3
      • Remove the three 6 mm screws that secure the board using a TR4 Torx screwdriver.
      Ask FixBot
    2. Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 15, image 1 of 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 15, image 2 of 3 Amazon Echo Show 8 3rd Gen Volume Buttons Replacement: step 15, image 3 of 3
      • Use an opening tool to flip open the black ZIF locking flap that secures the ribbon cable.
      • Be gentle with the ribbon cable.
      • Use tweezers to remove both buttons from the case.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 29
All Time: 362
