Amazon Echo Show 8 3rd Gen Speaker Replacement
  1. Amazon Echo Show 8 3rd Gen Speaker Replacement, Power Board: step 1, image 1 of 3 Amazon Echo Show 8 3rd Gen Speaker Replacement, Power Board: step 1, image 2 of 3 Amazon Echo Show 8 3rd Gen Speaker Replacement, Power Board: step 1, image 3 of 3
    • Use a prying tool to remove the rubber foot at the bottom.
    • It is secured with adhesive and will lift off with some gentle prying.
    • Use an opening pick to remove the screw cover.
  2. Amazon Echo Show 8 3rd Gen Speaker Replacement: step 2, image 1 of 2 Amazon Echo Show 8 3rd Gen Speaker Replacement: step 2, image 2 of 2
    • Use a Torx TR8 screwdriver to remove the two 2 cm screws.
  3. Amazon Echo Show 8 3rd Gen Speaker Replacement: step 3, image 1 of 2 Amazon Echo Show 8 3rd Gen Speaker Replacement: step 3, image 2 of 2
    • Insert a jimmy in the gap between the display and chassis.
    • Pry around the perimeter until the back case releases.
    • Be careful as to not damage the ribbon cable on the top left area of the screen.
    • Remove the back case.
  4. Amazon Echo Show 8 3rd Gen Speaker Replacement: step 4, image 1 of 3 Amazon Echo Show 8 3rd Gen Speaker Replacement: step 4, image 2 of 3 Amazon Echo Show 8 3rd Gen Speaker Replacement: step 4, image 3 of 3
    • Use a Torx TR6 screwdriver to remove the two 5 mm screws that secure the power board.
    • Carefully lift the board without straining the ribbon cable.
    • Using an opening tool, carefully flip up the black ZIF locking flap that secures the ribbon cable.
    • Disconnect the ribbon cable.
  5. Amazon Echo Show 8 3rd Gen Speaker Replacement, Speakers: step 5, image 1 of 3 Amazon Echo Show 8 3rd Gen Speaker Replacement, Speakers: step 5, image 2 of 3 Amazon Echo Show 8 3rd Gen Speaker Replacement, Speakers: step 5, image 3 of 3
    • Gently tilt the shell towards the top of the device and disconnect the ribbon cable from the board on the case.
    • Don't tilt the cable too much as you can damage the ribbon or the connector.
  6. Amazon Echo Show 8 3rd Gen Speaker Replacement: step 6, image 1 of 3 Amazon Echo Show 8 3rd Gen Speaker Replacement: step 6, image 2 of 3 Amazon Echo Show 8 3rd Gen Speaker Replacement: step 6, image 3 of 3
    • Use a TR6 screwdriver to remove the six 7mm screws located around the speaker assembly.
    • Gently tilt the speaker assembly towards the ribbon cable.
    • The ribbon cable is fragile and can be damaged if moved any other way.
    • Flip open the black tab on the connector towards the cable and gently pull.
    • Don't use too much force pulling up on the tab, as it can break and the cable will no longer be properly connected.
  7. Amazon Echo Show 8 3rd Gen Speaker Replacement: step 7, image 1 of 3 Amazon Echo Show 8 3rd Gen Speaker Replacement: step 7, image 2 of 3 Amazon Echo Show 8 3rd Gen Speaker Replacement: step 7, image 3 of 3
    • Use a TR6 Torx screwdriver to remove the eight 9 mm screws holding the metal bracket.
    • Gently lift off the metal bracket.
  8. Amazon Echo Show 8 3rd Gen Speaker Replacement: step 8, image 1 of 3 Amazon Echo Show 8 3rd Gen Speaker Replacement: step 8, image 2 of 3 Amazon Echo Show 8 3rd Gen Speaker Replacement: step 8, image 3 of 3
    • Remove the 2 rubber stoppers.
    • Remove all 14 screws with a Phillips #1 screwdriver.
  9. Amazon Echo Show 8 3rd Gen Speaker Replacement: step 9, image 1 of 3 Amazon Echo Show 8 3rd Gen Speaker Replacement: step 9, image 2 of 3 Amazon Echo Show 8 3rd Gen Speaker Replacement: step 9, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the four 1.3 cm screws holding down each driver.
    • Gently pull the plastic plate towards the antenna cable.
    • There is a small antenna cable that is easy to rip off the solder joint, so lift carefully.
    • There are 8 screws on the long side of the housing, but there is no driver behind it, so you don't need to remove them.
  10. Amazon Echo Show 8 3rd Gen Speaker Replacement: step 10, image 1 of 2 Amazon Echo Show 8 3rd Gen Speaker Replacement: step 10, image 2 of 2
    • Pry the speakers from the housing with a spudger.
    • The speakers are connected to a spring-loaded pin connector which is attached to the black plastic using industrial hot glue, so while you can heat the glue to remove it, the plastic may melt and/or deform, so we wouldn't recommend it.
Repair didn’t go as planned? Try some basic troubleshooting.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 27
Past 30 Days: 75
All Time: 766
