Amazon Echo Show 8 3rd Gen Power Board Replacement
  1. Amazon Echo Show 8 3rd Gen Power Board Replacement, Power Board: step 1, image 1 of 3 Amazon Echo Show 8 3rd Gen Power Board Replacement, Power Board: step 1, image 2 of 3 Amazon Echo Show 8 3rd Gen Power Board Replacement, Power Board: step 1, image 3 of 3
    • Use a prying tool to remove the rubber foot at the bottom.
    • It is secured with adhesive and will lift off with some gentle prying.
    • Use an opening pick to remove the screw cover.
    Ask FixBot
  2. Amazon Echo Show 8 3rd Gen Power Board Replacement: step 2, image 1 of 2 Amazon Echo Show 8 3rd Gen Power Board Replacement: step 2, image 2 of 2
    • Use a Torx TR8 screwdriver to remove the two 2 cm screws.
    Ask FixBot
  3. Amazon Echo Show 8 3rd Gen Power Board Replacement: step 3, image 1 of 2 Amazon Echo Show 8 3rd Gen Power Board Replacement: step 3, image 2 of 2
    • Insert a jimmy in the gap between the display and chassis.
    • Pry around the perimeter until the back case releases.
    • Be careful as to not damage the ribbon cable on the top left area of the screen.
    • Remove the back case.
    Ask FixBot
  4. Amazon Echo Show 8 3rd Gen Power Board Replacement: step 4, image 1 of 3 Amazon Echo Show 8 3rd Gen Power Board Replacement: step 4, image 2 of 3 Amazon Echo Show 8 3rd Gen Power Board Replacement: step 4, image 3 of 3
    • Use a Torx TR6 screwdriver to remove the two 5 mm screws that secure the power board.
    • Carefully lift the board without straining the ribbon cable.
    • Using an opening tool, carefully flip up the black ZIF locking flap that secures the ribbon cable.
    • Disconnect the ribbon cable.
    Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 56
All Time: 446
