Amazon Echo Show 5-Megapixel Camera Replacement
    1. Amazon Echo Show 5-Megapixel Camera  Replacement, Camera: step 1, image 1 of 2 Amazon Echo Show 5-Megapixel Camera  Replacement, Camera: step 1, image 2 of 2
      • Use the plastic opening tool to gently lift the plastic protector from the screen.
      Ask FixBot
    2. Amazon Echo Show 5-Megapixel Camera  Replacement: step 2, image 1 of 2 Amazon Echo Show 5-Megapixel Camera  Replacement: step 2, image 2 of 2
      • After the protector has been removed, use your hands to gently remove the taped-in rubber foot from device.
      Ask FixBot
    3. Amazon Echo Show 5-Megapixel Camera  Replacement: step 3, image 1 of 1
      • Carefully peel off the bottom pad to expose the fastening screws.
      • Remove three silver 1.4 T5 Torx screws on the top row.
      • Remove one green 1mm T5 Torx screw in the middle.
      • Remove a black 1.5mm T5 screw.
      • Remove three green 1mm T5 screws from the bottom row.
      Ask FixBot
    4. Amazon Echo Show 5-Megapixel Camera  Replacement: step 4, image 1 of 3 Amazon Echo Show 5-Megapixel Camera  Replacement: step 4, image 2 of 3 Amazon Echo Show 5-Megapixel Camera  Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • After the screws are removed, grip the front panel and separate the front from the back. This will expose the inside of the device.
      • Make sure to ground yourself against a metal object nearby (ex. a metal chair, a door frame) before you touch any circuitry. An accidental static discharge can permanently damage a circuitboard.
      • Use tweezers or your hands to carefully disconnect the red wires connecting the speakers to the power supply board.
      • Lay the front section flat, with the screen down.
      Ask FixBot
    5. Amazon Echo Show 5-Megapixel Camera  Replacement: step 5, image 1 of 3 Amazon Echo Show 5-Megapixel Camera  Replacement: step 5, image 2 of 3 Amazon Echo Show 5-Megapixel Camera  Replacement: step 5, image 3 of 3
      • Remove two 1mm T5 Torx screws.
      • Once the screws have been removed, you can easily remove the camera from the device.
      Ask FixBot
1 Guide Comment
Can not reset amazon echo show model MW46WB tried everything any suggestions
Skippy Gessler - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 30
All Time: 2,582
