Amazon Echo Show 5 Camera Replacement
    1. Amazon Echo Show 5 Camera Replacement, Amazon Echo Show 5 Disassembly: step 1, image 1 of 3 Amazon Echo Show 5 Camera Replacement, Amazon Echo Show 5 Disassembly: step 1, image 2 of 3 Amazon Echo Show 5 Camera Replacement, Amazon Echo Show 5 Disassembly: step 1, image 3 of 3
      • Power off and unplug the Amazon Echo Show 5. Failure to do so could result in injury or damage to the device.
      • Orient the Amazon Echo Show 5 so that the display is face down.
      • Use a spudger to remove the grey bottom cover.
      • During reassembly, adhesive needs to be applied to secure the bottom cover.
      Ask FixBot
    2. Amazon Echo Show 5 Camera Replacement: step 2, image 1 of 2 Amazon Echo Show 5 Camera Replacement: step 2, image 2 of 2
      • Remove the three screws with a T6 Torx screwdriver.
      Ask FixBot
    3. Amazon Echo Show 5 Camera Replacement: step 3, image 1 of 3 Amazon Echo Show 5 Camera Replacement: step 3, image 2 of 3 Amazon Echo Show 5 Camera Replacement: step 3, image 3 of 3
      • Use a spudger to release the six internal tabs lining the sides of the device.
      • There are fragile ribbon connectors along the side of the screen with the camera on it. So, do not stick the spudger more than a couple millimeters into the device.
      Ask FixBot
    4. Amazon Echo Show 5 Camera Replacement: step 4, image 1 of 1
      • Carefully open the device by folding it open along the top edge where the camera is located.
      • Do not try to open the device from any other side as this would damage the ribbon connectors.
      Ask FixBot
    1. Amazon Echo Show 5 Camera Replacement, Motherboard: step 5, image 1 of 1
      • Remove the red and black power connector connecting to the motherboard with either a prying tool or your hands.
      Ask FixBot
    2. Amazon Echo Show 5 Camera Replacement: step 6, image 1 of 2 Amazon Echo Show 5 Camera Replacement: step 6, image 2 of 2
      • Disconnect the five ribbon cables connecting to the motherboard.
      • To disconnect the cables, use the tip of a prying tool, or your fingernail, to flip up the small locking flap. Then, you can safely pull the cable out.
      • Be sure to pry up the hinged flap, not the connector socket.
      • There is a white line on the ribbon connectors that indicates the edge of the connection area. To reinstall, insert the connector up to this white line and close the flap. If the white line is clearly visible after closing the flap, it is probably misaligned and needs to be repositioned.
      Ask FixBot
    3. Amazon Echo Show 5 Camera Replacement: step 7, image 1 of 1
      • Remove the six 4 mm screws that are used to hold down the motherboard using a T6 Security Torx Screwdriver.
      Ask FixBot
    4. Amazon Echo Show 5 Camera Replacement: step 8, image 1 of 2 Amazon Echo Show 5 Camera Replacement: step 8, image 2 of 2
      • Lift the motherboard up and out.
      Ask FixBot
    1. Amazon Echo Show 5 Camera Replacement, Microphone: step 9, image 1 of 3 Amazon Echo Show 5 Camera Replacement, Microphone: step 9, image 2 of 3 Amazon Echo Show 5 Camera Replacement, Microphone: step 9, image 3 of 3
      Tool used on this step:
      Buy
      • Use the Philips #000 Screwdriver to remove two 4mm screws that hold down the metal bracket.
      • Use tweezers to remove the metal bracket by lifting it up and towards yourself.
      Ask FixBot
    2. Amazon Echo Show 5 Camera Replacement: step 10, image 1 of 3 Amazon Echo Show 5 Camera Replacement: step 10, image 2 of 3 Amazon Echo Show 5 Camera Replacement: step 10, image 3 of 3
      • Use a spudger or your fingernail to remove the ribbon connector which connects the speaker housing board to the microphone board.
      • Ribbon connectors are very fragile, do not bend kink or bend them excessively. This will result in damage to the device.
      • There is a white line on the ribbon connector. During reassembly ensure that the white connector is inserted up to the white line and that the white line is not misaligned with the ribbon connector.
      Ask FixBot
    3. Amazon Echo Show 5 Camera Replacement: step 11, image 1 of 3 Amazon Echo Show 5 Camera Replacement: step 11, image 2 of 3 Amazon Echo Show 5 Camera Replacement: step 11, image 3 of 3
      • Use the Philips #000 Screwdriver to remove the four 4 mm screws that attach the microphone board to the case.
      Ask FixBot
    4. Amazon Echo Show 5 Camera Replacement: step 12, image 1 of 2 Amazon Echo Show 5 Camera Replacement: step 12, image 2 of 2
      • Use a tweezer to remove the microphone board from the case.
      Ask FixBot
    1. Amazon Echo Show 5 Camera Replacement, Camera: step 13, image 1 of 2 Amazon Echo Show 5 Camera Replacement, Camera: step 13, image 2 of 2
      Buy
      • Use tweezers to remove the camera from the display assembly.
      • The camera has adhesive on the ribbon connector which needs to be reapplied in order to reassemble it.
      • The ribbon connector attached to the camera is very fragile. Avoid bending or kinking the connector as this will cause damage to the device.
      Ask FixBot
Nicholas Sardinha
247 Reputation
2 Guides authored
UMass Dartmouth, Team 2-4, Petersen Fall 2022 Member of UMass Dartmouth, Team 2-4, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G4
3 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 28
All Time: 871
