Amazon Echo Show 15 Motherboard Replacement
  1. Amazon Echo Show 15 Motherboard Replacement, Back Panel: step 1, image 1 of 3 Amazon Echo Show 15 Motherboard Replacement, Back Panel: step 1, image 2 of 3 Amazon Echo Show 15 Motherboard Replacement, Back Panel: step 1, image 3 of 3
    • Remove the four white stickers on your device's back panel.
    • Due to the strong adhesive supporting the stickers, we recommend heating them up to make removal easier.
    • A hair dryer may work best for this step.
    Ask FixBot
  2. Amazon Echo Show 15 Motherboard Replacement: step 2, image 1 of 3 Amazon Echo Show 15 Motherboard Replacement: step 2, image 2 of 3 Amazon Echo Show 15 Motherboard Replacement: step 2, image 3 of 3
    • Unscrew the four 50 mm screws with a T3 Torx screwdriver.
    • Pop the sides and remove the back panel of the device.
    Ask FixBot
  3. Amazon Echo Show 15 Motherboard Replacement, Motherboard: step 3, image 1 of 3 Amazon Echo Show 15 Motherboard Replacement, Motherboard: step 3, image 2 of 3 Amazon Echo Show 15 Motherboard Replacement, Motherboard: step 3, image 3 of 3
    • Remove the five 3 mm screws from the metal protector using a Torx T5 screwdriver.
    • Take off the metal protector.
    • The metal protector is connected to the motherboard with adhesive. More force may be necessary.
    • Remove the twelve 3 mm screws from the motherboard using the Torx T5 screwdriver.
    Ask FixBot
  4. Amazon Echo Show 15 Motherboard Replacement: step 4, image 1 of 3 Amazon Echo Show 15 Motherboard Replacement: step 4, image 2 of 3 Amazon Echo Show 15 Motherboard Replacement: step 4, image 3 of 3
    • Detach the connectors for the camera and buttons from the motherboard.
    • Detach the connectors for the power station and speakers from the motherboard.
    • Detach the small white coaxial cables from the motherboard.
    • These connectors will be reused, so be very careful with them. The small white connectors come off by being pulled up.
    Ask FixBot
  5. Amazon Echo Show 15 Motherboard Replacement: step 5, image 1 of 1
    • Remove the motherboard from the main device.
    Ask FixBot
Paysen Hudson
208 Reputation
2 Guides authored
3 Guide Comments
can i buy replacement? who?
Angel R Hernandez - Reply Share
Where can I purchase the motherboard? I've googled, but can't find anything to come up.....Amazon doesn't show it as a replacement part either. Thanks in advance!
Roxanna Caspar - Reply Share
Anywhere I can purchase a new motherboard for the Amazon Echo Show 15 ??
Any help would be very much appreciated.
Mr Colin Campbell - Reply Share
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 102
All Time: 1,483
