Amazon Echo Show 15 Microphone Replacement
Views: 1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
65
All Time:
1,028
Comments: 3
1 comment on steps, 2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If the microphone in your Amazon Echo Show 15 (model H6Y2A5) is not picking up your voice in calls, distorting your audio, or is giving a heavy feedback loop, use this guide to replace it.
The microphone on an Amazon Echo Show 15 plays a crucial role in picking up sound and providing users with excellent communication. Issues with unresponsive microphones can disrupt the user experience.
Before diving into the replacement process, ensure your device is completely powered off and disconnected from any external power sources. This guide provides a step-by-step walkthrough to address microphone replacement and restore optimal functionality to your Amazon Echo Show 15.
Tools
    1. Amazon Echo Show 15 Microphone Replacement, Back Panel: step 1, image 1 of 3 Amazon Echo Show 15 Microphone Replacement, Back Panel: step 1, image 2 of 3 Amazon Echo Show 15 Microphone Replacement, Back Panel: step 1, image 3 of 3
      • Remove the four white stickers on your device's back panel.
      • Due to the strong adhesive supporting the stickers, we recommend heating them up to make removal easier.
      • A hair dryer may work best for this step.
      Ask FixBot
    2. Amazon Echo Show 15 Microphone Replacement: step 2, image 1 of 3 Amazon Echo Show 15 Microphone Replacement: step 2, image 2 of 3 Amazon Echo Show 15 Microphone Replacement: step 2, image 3 of 3
      • Unscrew the four 50 mm screws with a T3 Torx screwdriver.
      • Pop the sides and remove the back panel of the device.
      Ask FixBot
    1. Amazon Echo Show 15 Microphone Replacement, Inner Black Panel: step 3, image 1 of 3 Amazon Echo Show 15 Microphone Replacement, Inner Black Panel: step 3, image 2 of 3 Amazon Echo Show 15 Microphone Replacement, Inner Black Panel: step 3, image 3 of 3
      • In the top right corner you will find a small black panel.
      • Remove the five 2 mm screws with a Torx T5 screwdriver.
      • Remove the two 5 mm with a Torx T3 screwdriver.
      • Remove both ends of the connector from the main device.
      • Remove the black panel.
      Ask FixBot
    1. Amazon Echo Show 15 Microphone Replacement, Microphone: step 4, image 1 of 2 Amazon Echo Show 15 Microphone Replacement, Microphone: step 4, image 2 of 2
      • Locate the microphone panel on the top right hand corner.
      • Remove the two 3 mm screws with a Torx T3 screwdriver.
      Ask FixBot
    2. Amazon Echo Show 15 Microphone Replacement: step 5, image 1 of 2 Amazon Echo Show 15 Microphone Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the microphone.
      • You may use tweezers for this step if necessary.
      Ask FixBot
Talara
318 Reputation
3 Guides authored
2 Guide Comments
Great tutorial. One question though, where do you get the new microphone?
Trevor Richardson - Reply Share
Hi what is the other wire on the top that displays mic as well ?
Eddy Elias - Reply Share
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 65
All Time: 1,028
