Amazon Echo Show 10 3rd Gen Woofer Replacement
    1. Amazon Echo Show 10 3rd Gen Woofer Replacement, Woofer: step 1, image 1 of 2 Amazon Echo Show 10 3rd Gen Woofer Replacement, Woofer: step 1, image 2 of 2
      • With the echo device standing upright, firmly grip the base and use the blue opening tool to gently pry the lid from the mesh speaker base.
      • Remove the lid and set it aside.
      Ask FixBot
    2. Amazon Echo Show 10 3rd Gen Woofer Replacement: step 2, image 1 of 1
      • Use a Phillips #2 screwdriver to remove the six 13 mm screws along the perimeter of the speaker.
      Ask FixBot
    3. Amazon Echo Show 10 3rd Gen Woofer Replacement: step 3, image 1 of 2 Amazon Echo Show 10 3rd Gen Woofer Replacement: step 3, image 2 of 2
      • Use an opening tool to pry up along the edge of the speaker.
      • Gently lift the woofer out of the device.
      • The woofer is connected to a cable so don't yank it out or you will damage the connector.
      Ask FixBot
    4. Amazon Echo Show 10 3rd Gen Woofer Replacement: step 4, image 1 of 1
      • Tilt the woofer so the side with the cables is angled upwards.
      • Desolder the three separate cable connectors from the woofer attached to the plate using a soldering iron.
      • For information on soldering, refer to the How to Solder and Desolder Connections guide.
      Ask FixBot
    5. Amazon Echo Show 10 3rd Gen Woofer Replacement: step 5, image 1 of 1
      • After desoldering the three cables, lift the woofer out of the shell of the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 35
All Time: 511
