Amazon Echo Show 10 3rd Gen Display Replacement
Views: 3.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
43
Past 30 Days:
162
All Time:
3,107
Comments: 6
6 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 40 - 55 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide will walk you through the replacement process for the display found within your Amazon Echo Show 10 3rd Gen device. The display is responsible for showing the UI of the device as well as allowing the user to control the device's settings and functions. If you are having problems with the device display not turning on, not responding to touch controls, or it is cracked or damaged, replacement may be necessary.
If possible, a restart of the device using the physical power button is recommended before replacement of the screen, since that may fix the issue without the need for disassembly. Please make sure to refer to the Amazon Echo Show 10 3rd Gen troubleshooting page before committing to replacement.
If the screen of your device is cracked or shattered, please refer to the guide linked here for information on preparing broken screens for replacement.
Tools
    1. Amazon Echo Show 10 3rd Gen Display Replacement, Display: step 1, image 1 of 2 Amazon Echo Show 10 3rd Gen Display Replacement, Display: step 1, image 2 of 2
      • With the Echo device standing upright, firmly grip the base and use the blue opening tool to gently pry the lid from the mesh speaker base.
      • Remove the lid and set aside.
      Ask FixBot
    2. Amazon Echo Show 10 3rd Gen Display Replacement: step 2, image 1 of 1
      • Use a TR8 Torx Security screwdriver to remove the six 9 mm screws from the perimeter of the plastic bezel on the top edge of the device.
      Ask FixBot
    3. Amazon Echo Show 10 3rd Gen Display Replacement: step 3, image 1 of 2 Amazon Echo Show 10 3rd Gen Display Replacement: step 3, image 2 of 2
      • Release the adhesive seal connecting the bezel to the main base by inserting a Jimmy underneath the edge, and gently sliding from one side to another.
      • Lift up the outermost edge of the plastic bezel (furthest from the display) to remove it and set it aside.
      • After removing the screws in the previous step, the only thing holding this component in place is glue. You may need to apply a little force to break the seal created by any remaining glue to remove the bezel component. You could also apply a little heat with the iOpener to loosen the adhesive.
      Ask FixBot
    4. Amazon Echo Show 10 3rd Gen Display Replacement: step 4, image 1 of 1
      • Use a Torx T6 screwdriver to remove the five 10 mm screws from the perimeter of the top surface of the base.
      Ask FixBot
    5. Amazon Echo Show 10 3rd Gen Display Replacement: step 5, image 1 of 2 Amazon Echo Show 10 3rd Gen Display Replacement: step 5, image 2 of 2
      • With one hand securely holding the neck of the display and the other holding the device base, gently lift the device out of the mesh shell.
      • Place the shell aside.
      Ask FixBot
    6. Amazon Echo Show 10 3rd Gen Display Replacement: step 6, image 1 of 1
      • Tilt the device so that the underside of the display and its neck are facing you.
      • You may need help holding it in this position. Alternatively, you could place the device on a soft surface so it doesn't get damaged.
      • Use a T6 Torx screwdriver to remove the two 5mm screws from the underside of the display neck.
      Ask FixBot
    7. Amazon Echo Show 10 3rd Gen Display Replacement: step 7, image 1 of 2 Amazon Echo Show 10 3rd Gen Display Replacement: step 7, image 2 of 2
      • Lift the plate up to remove it from the neck of the device.
      • Set it aside for reassembly.
      Ask FixBot
    8. Amazon Echo Show 10 3rd Gen Display Replacement: step 8, image 1 of 1
      • Use an opening tool to flip up the small locking flap on the ribbon cable connector located in the center of the exposed underside of the display neck.
      • Gently pull the cable out.
      Ask FixBot
    9. Amazon Echo Show 10 3rd Gen Display Replacement: step 9, image 1 of 1
      • Tilt the device so it is in the upright position.
      • Use a TR10 Torx Security screwdriver to remove the four 11 mm screws from the top of the display neck.
      Ask FixBot
    10. Amazon Echo Show 10 3rd Gen Display Replacement: step 10, image 1 of 2 Amazon Echo Show 10 3rd Gen Display Replacement: step 10, image 2 of 2
      • Gently lift the display and its connecting neck off of the base.
      Ask FixBot
6 Guide Comments
any idea where to purchase a replacement display?
Don Jackson - Reply Share
Were you able to source a replacement display? I'm having troubles finding one. Thanks
Jeg4 - Reply Share
where can I buy a replacement display for echo 10 3rd gen?
Tomasz K. - Reply Share
@tomaszk64280 por la plataforma de amazon, pero no aparece el tutorial para cambiar solo la pantalla
ARIAS SEGUROS Y CIA LTDA - Reply Share
Wenn ihr eine Quelle gefunden habt wäre eine info schön ich suche nun auch nach einem kleinen missgeschick...
Jan Pfotenhauer - Reply Share
Past 24 Hours: 2
Past 7 Days: 43
Past 30 Days: 162
All Time: 3,107
