Up to 20% off select tools
Amazon Echo Look Wi-Fi Module Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
73
All Time:
690
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 35 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
Introduction
Go to step 1 ↓
The Amazon Echo Look's primary function as a fashion assistant can be affected if the Wi-Fi module is damaged. The device uses Wi-Fi in order to use its main features such as looking for wardrobes; a damaged Wi-Fi module can hinder that.
    1. Amazon Echo Look Wi-Fi Module Replacement, Front Panel: step 1, image 1 of 1
      • Ensure the device is completely powered off and disconnected from any power source by removing the charger adapter point from the back of the device.
      Ask FixBot
    2. Amazon Echo Look Wi-Fi Module Replacement: step 2, image 1 of 3 Amazon Echo Look Wi-Fi Module Replacement: step 2, image 2 of 3 Amazon Echo Look Wi-Fi Module Replacement: step 2, image 3 of 3
      • If the device stand is attached, remove it by twisting the device's base toward yourself until detached.
      Ask FixBot
    3. Amazon Echo Look Wi-Fi Module Replacement: step 3, image 1 of 1
      • Heat the front panel with an iOpener.
      • It may help to secure the iOpener to the device.
      • Heat the device for 5-10 minutes to loosen the glue.
      • CAUTION: The iOpener and the device may be hot.
      Ask FixBot
    4. Amazon Echo Look Wi-Fi Module Replacement: step 4, image 1 of 3 Amazon Echo Look Wi-Fi Module Replacement: step 4, image 2 of 3 Amazon Echo Look Wi-Fi Module Replacement: step 4, image 3 of 3
      • Lever the Jimmy between the screen and the device until an opening is formed.
      • Insert opening picks to hold the opening as needed.
      • Use a spudger to circle the border of the front panel and disconnect any lingering glue.
      • Step 3 may need to be repeated as Step 4 is time-sensitive.
      Ask FixBot
    5. Amazon Echo Look Wi-Fi Module Replacement: step 5, image 1 of 2 Amazon Echo Look Wi-Fi Module Replacement: step 5, image 2 of 2
      • Remove the front panel by levering the spudger at the top of the device.
      Ask FixBot
    1. Amazon Echo Look Wi-Fi Module Replacement, Midframe: step 6, image 1 of 2 Amazon Echo Look Wi-Fi Module Replacement, Midframe: step 6, image 2 of 2
      • Remove the screws from the midframe with a Torx T5 screwdriver.
      • Lift up the midframe
      • Remove the eight screws attached to the gray metal piece using a Torx T5 screwdriver.
      Ask FixBot
    2. Amazon Echo Look Wi-Fi Module Replacement: step 7, image 1 of 2 Amazon Echo Look Wi-Fi Module Replacement: step 7, image 2 of 2
      • Use a spudger to gently lift up the ribbon until it detaches.
      Ask FixBot
    1. Amazon Echo Look Wi-Fi Module Replacement, Wi-Fi Module: step 8, image 1 of 1
      • Use a spudger to pry the Wi-Fi module away from the motherboard.
      Ask FixBot
Author
with
Ryánn Gillen
428 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 73
All Time: 690
