Amazon Echo Look Speaker Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
12
Past 30 Days:
57
All Time:
395
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 35 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Needs More Images
A few more images would make this guide's procedures crystal clear.
Introduction
Go to step 1 ↓
This guide will go more into detail about how to replace the speaker for the Amazon Echo Look device. The speaker is responsible for one of the main functionalities of the device which is to let Alexa relay information to the user.
Tools
    1. Amazon Echo Look Speaker Replacement, Front Panel: step 1, image 1 of 1
      • Ensure the device is completely powered off and disconnected from any power source by removing the charger adapter point from the back of the device.
      Ask FixBot
    2. Amazon Echo Look Speaker Replacement: step 2, image 1 of 3 Amazon Echo Look Speaker Replacement: step 2, image 2 of 3 Amazon Echo Look Speaker Replacement: step 2, image 3 of 3
      • If the device stand is attached, remove it by twisting the device's base toward yourself until detached.
      Ask FixBot
    3. Amazon Echo Look Speaker Replacement: step 3, image 1 of 1
      • Heat the front panel with an iOpener.
      • It may help to secure the iOpener to the device.
      • Heat the device for 5-10 minutes to loosen the glue.
      • CAUTION: The iOpener and the device may be hot.
      Ask FixBot
    4. Amazon Echo Look Speaker Replacement: step 4, image 1 of 3 Amazon Echo Look Speaker Replacement: step 4, image 2 of 3 Amazon Echo Look Speaker Replacement: step 4, image 3 of 3
      • Lever the Jimmy between the screen and the device until an opening is formed.
      • Insert opening picks to hold the opening as needed.
      • Use a spudger to circle the border of the front panel and disconnect any lingering glue.
      • Step 3 may need to be repeated as Step 4 is time-sensitive.
      Ask FixBot
    5. Amazon Echo Look Speaker Replacement: step 5, image 1 of 2 Amazon Echo Look Speaker Replacement: step 5, image 2 of 2
      • Remove the front panel by levering the spudger at the top of the device.
      Ask FixBot
    1. Amazon Echo Look Speaker Replacement, Midframe: step 6, image 1 of 2 Amazon Echo Look Speaker Replacement, Midframe: step 6, image 2 of 2
      • Remove the screws from the midframe with a Torx T5 screwdriver.
      • Lift up the midframe
      • Remove the eight screws attached to the gray metal piece using a Torx T5 screwdriver.
      Ask FixBot
    2. Amazon Echo Look Speaker Replacement: step 7, image 1 of 2 Amazon Echo Look Speaker Replacement: step 7, image 2 of 2
      • Use a spudger to gently lift up the ribbon until it detaches.
      Ask FixBot
    1. Amazon Echo Look Speaker Replacement, Wi-Fi Module: step 8, image 1 of 1
      • Use a spudger to pry the Wi-Fi module away from the motherboard.
      Ask FixBot
    1. Amazon Echo Look Speaker Replacement, Motherboard: step 9, image 1 of 3 Amazon Echo Look Speaker Replacement, Motherboard: step 9, image 2 of 3 Amazon Echo Look Speaker Replacement, Motherboard: step 9, image 3 of 3
      • Remove five screws from the motherboard with a T4 Torx screwdriver.
      • Remove all attached parts.
      • Tilting the device, angle the motherboard for removal.
      Ask FixBot
    1. Amazon Echo Look Speaker Replacement, Speaker: step 10, image 1 of 1
      • Remove screws with a T4 Torx screwdriver.
      • Using pliers, remove the copper-plated sections.
      Ask FixBot
    2. Amazon Echo Look Speaker Replacement: step 11, image 1 of 2 Amazon Echo Look Speaker Replacement: step 11, image 2 of 2
      • Remove the speaker with pliers.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 57
All Time: 395
