Up to 20% off select tools
Amazon Echo Look Midframe Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
9
Past 30 Days:
72
All Time:
391
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
    1. Amazon Echo Look Midframe Replacement, Front Panel: step 1, image 1 of 1
      • Ensure the device is completely powered off and disconnected from any power source by removing the charger adapter point from the back of the device.
      Ask FixBot
    2. Amazon Echo Look Midframe Replacement: step 2, image 1 of 3 Amazon Echo Look Midframe Replacement: step 2, image 2 of 3 Amazon Echo Look Midframe Replacement: step 2, image 3 of 3
      • If the device stand is attached, remove it by twisting the device's base toward yourself until detached.
      Ask FixBot
    3. Amazon Echo Look Midframe Replacement: step 3, image 1 of 1
      • Heat the front panel with an iOpener.
      • It may help to secure the iOpener to the device.
      • Heat the device for 5-10 minutes to loosen the glue.
      • CAUTION: The iOpener and the device may be hot.
      Ask FixBot
    4. Amazon Echo Look Midframe Replacement: step 4, image 1 of 3 Amazon Echo Look Midframe Replacement: step 4, image 2 of 3 Amazon Echo Look Midframe Replacement: step 4, image 3 of 3
      • Lever the Jimmy between the screen and the device until an opening is formed.
      • Insert opening picks to hold the opening as needed.
      • Use a spudger to circle the border of the front panel and disconnect any lingering glue.
      • Step 3 may need to be repeated as Step 4 is time-sensitive.
      Ask FixBot
    5. Amazon Echo Look Midframe Replacement: step 5, image 1 of 2 Amazon Echo Look Midframe Replacement: step 5, image 2 of 2
      • Remove the front panel by levering the spudger at the top of the device.
      Ask FixBot
    1. Amazon Echo Look Midframe Replacement, Midframe: step 6, image 1 of 2 Amazon Echo Look Midframe Replacement, Midframe: step 6, image 2 of 2
      • Remove the screws from the midframe with a Torx T5 screwdriver.
      • Lift up the midframe
      • Remove the eight screws attached to the gray metal piece using a Torx T5 screwdriver.
      Ask FixBot
    2. Amazon Echo Look Midframe Replacement: step 7, image 1 of 2 Amazon Echo Look Midframe Replacement: step 7, image 2 of 2
      • Use a spudger to gently lift up the ribbon until it detaches.
      Ask FixBot
Author
with
Prince Boateng
88 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 72
All Time: 391
