Up to 20% off select tools
Amazon Echo Look Front Panel Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
19
Past 30 Days:
75
All Time:
428
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 45 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The Amazon Echo Look's primary function as a fashion assistance can be affected if the front panel is cracked or if the lens is smudged on the inside or otherwise damaged.
Some steps are time-sensitive and may need to be repeated- the time estimate reflects this.
    1. Amazon Echo Look Front Panel Replacement, Front Panel: step 1, image 1 of 1
      • Ensure the device is completely powered off and disconnected from any power source by removing the charger adapter point from the back of the device.
      Ask FixBot
    2. Amazon Echo Look Front Panel Replacement: step 2, image 1 of 3 Amazon Echo Look Front Panel Replacement: step 2, image 2 of 3 Amazon Echo Look Front Panel Replacement: step 2, image 3 of 3
      • If the device stand is attached, remove it by twisting the device's base toward yourself until detached.
      Ask FixBot
    3. Amazon Echo Look Front Panel Replacement: step 3, image 1 of 1
      • Heat the front panel with an iOpener.
      • It may help to secure the iOpener to the device.
      • Heat the device for 5-10 minutes to loosen the glue.
      • CAUTION: The iOpener and the device may be hot.
      Ask FixBot
    4. Amazon Echo Look Front Panel Replacement: step 4, image 1 of 3 Amazon Echo Look Front Panel Replacement: step 4, image 2 of 3 Amazon Echo Look Front Panel Replacement: step 4, image 3 of 3
      • Lever the Jimmy between the screen and the device until an opening is formed.
      • Insert opening picks to hold the opening as needed.
      • Use a spudger to circle the border of the front panel and disconnect any lingering glue.
      • Step 3 may need to be repeated as Step 4 is time-sensitive.
      Ask FixBot
    5. Amazon Echo Look Front Panel Replacement: step 5, image 1 of 2 Amazon Echo Look Front Panel Replacement: step 5, image 2 of 2
      • Remove the front panel by levering the spudger at the top of the device.
      Ask FixBot
Author
with
Ryánn Gillen
428 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 75
All Time: 428
