Introduction
The Amazon Echo Glow motherboard is responsible for all functions of the Amazon Echo Glow. If the Motherboard is damaged or faulty, the Amazon Echo Glow will not be useable. This repair guide will guide you through the step by step process of removing and replacing the Amazon Echo Glow motherboard.
- CAUTION! When working on any electrical components, it is vitally important to be sure that the device is completely powered off prior to making any repairs. Additionally, internal components can still retain electrical charge long after being powered off. To maintain your safety, be sure that your work space is clean of any moisture or debris, and remove any conductive items such as rings, bracelets or watches.
Using the metal spudger, insert it into the seam between the outer shell and the base of the Amazon Echo Glow. Break open the glued seal that holds the outer shell to get into the device.
- Reminder: Reseal the device by using hot glue around the seam of the outer shell
