Introduction
If your Amazon Echo Glow suffers from structural failure like a snapped plastic component, a jammed or stuck action button, or a faulty internal power board, it may be due to a damaged internal frame. This guide will help you step by step to remove and replace the internal frame safely for the Amazon Echo Glow. The internal frame is responsible for the structure of the overall device. It adds weight and stability, is a screw anchor point, gives structural support, and helps to dissipate heat. When replacing the internal frame, it is very possible to break clips, wiring, or LEDs, so it's very important to do this replacement very cautiously.
CAUTION! When working on any electrical components, it is vitally important to be sure that the device is completely powered off prior to making any repairs. Additionally, internal components can still retain electrical charge long after being powered off. To maintain your safety, be sure that your work space is clean of any moisture or debris, and remove any conductive items such as rings, bracelets or watches.
Using the metal spudger, insert it into the seam between the outer shell and the base of the Amazon Echo Glow. Break open the glued seal that holds the outer shell to get into the device.
Use s T10 Torx screwdriver to remove the four screws securing the bracket.
