Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement
  1. Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement, Motherboard: step 1, image 1 of 2 Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement, Motherboard: step 1, image 2 of 2
    • Using a spudger, remove the rubber footing around the base of the Echo Dot. This will reveal the four T8 1.25 cm Torx screws.
    Ask FixBot
  2. Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement: step 2, image 1 of 1
    • Once removed, the Echo Dot is now able to be split in two.
    • The ribbon cable connecting the microphone to the CPU PCB is now exposed, be careful not to tear it. The lower case will have the LED diffuser along the bottom, while the upper case will contain the rest of the internals.
    Ask FixBot
  3. Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement: step 3, image 1 of 3 Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement: step 3, image 2 of 3 Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement: step 3, image 3 of 3
    • Remove the CPU PCB by removing the 4 T6 0.75cm Torx screws.
    • Once removed, unclip the plastic retainer on the CPU PCB and slide the ribbon cable out. This will reveal the speaker’s metal housing.
    Ask FixBot
  4. Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement, Ribbon Cable: step 4, image 1 of 1
    • Now, use a plastic prying tool to remove the ribbon cable from the speaker housing.
    Ask FixBot
  5. Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement: step 5, image 1 of 1
    • Using the Torx T8 bit, remove the four 1.25 cm screws around the edges of the speaker housing, and lift the housing off of the top case, revealing the switch PCB.
    Ask FixBot
  6. Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement: step 6, image 1 of 3 Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement: step 6, image 2 of 3 Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement: step 6, image 3 of 3
    • Use a plastic spudger to undo the adhesive attaching the ribbon cable to the top case. Then, flip the tab on the switch PCB, and slide out the ribbon cable.
    Ask FixBot
  7. Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement, Switch PCB: step 7, image 1 of 3 Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement, Switch PCB: step 7, image 2 of 3 Amazon Echo Dot 5th Generation Switch PCB Replacement Replacement, Switch PCB: step 7, image 3 of 3
    • Remove the upper switch PCB using the T4 Torx bit to unscrew the four 5 mm screws.
    • The PCB is glued down in between the 4 buttons.
    • Push down on the buttons through the top of the case and pry lightly with plastic tools until loose, then remove.
    Ask FixBot
Catherinej
91 Reputation
1 Guide authored
UMass Dartmouth, Team 3-4, Konn Fall 2023 Member of UMass Dartmouth, Team 3-4, Konn Fall 2023
UMASSD-KONN-F23S3G4
4 Members
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 76
All Time: 1,109
