Amazon Echo Dot 3rd Generation Motherboard Replacement
  1. Amazon Echo Dot 3rd Generation Motherboard Replacement, Casing: step 1, image 1 of 3 Amazon Echo Dot 3rd Generation Motherboard Replacement, Casing: step 1, image 2 of 3 Amazon Echo Dot 3rd Generation Motherboard Replacement, Casing: step 1, image 3 of 3
    • Turn the Echo Dot over so the barcode is facing up, giving you access to the bottom of the device.
    Ask FixBot
  2. Amazon Echo Dot 3rd Generation Motherboard Replacement: step 2, image 1 of 2 Amazon Echo Dot 3rd Generation Motherboard Replacement: step 2, image 2 of 2
    • Use a spudger to gently lift the adhesive covering between the casing and the device.
    Ask FixBot
  3. Amazon Echo Dot 3rd Generation Motherboard Replacement: step 3, image 1 of 1
    • Use a T6 Torx screwdriver to remove the four 7.2 mm screws located around the corners of the device.
    • Make sure to keep the screws in a safe place for the reassembly process.
    Ask FixBot
  4. Amazon Echo Dot 3rd Generation Motherboard Replacement: step 4, image 1 of 2 Amazon Echo Dot 3rd Generation Motherboard Replacement: step 4, image 2 of 2
    • Gently lift the casing of the device, starting from one side.
    • If the casing is stuck, use the spudger to carefully loosen it along the edges.
    • Be careful not to damage any internal components of the device.
    Ask FixBot
  5. Amazon Echo Dot 3rd Generation Motherboard Replacement, Motherboard: step 5, image 1 of 3 Amazon Echo Dot 3rd Generation Motherboard Replacement, Motherboard: step 5, image 2 of 3 Amazon Echo Dot 3rd Generation Motherboard Replacement, Motherboard: step 5, image 3 of 3
    • Remove the four 6.2 mm screws from the motherboard using a T6 Torx screwdriver.
    • Remove the three 9.4 mm screws from the motherboard using a T6 Torx screwdriver.
    Ask FixBot
  6. Amazon Echo Dot 3rd Generation Motherboard Replacement: step 6, image 1 of 3 Amazon Echo Dot 3rd Generation Motherboard Replacement: step 6, image 2 of 3 Amazon Echo Dot 3rd Generation Motherboard Replacement: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the connecting head linking the motherboard to the device using a pair of tweezers.
    • Remove the old motherboard and replace it with the new one.
    Ask FixBot
4 other people completed this guide.
3 Guide Comments
Where do we get the parts you bi chh
Fcukermother - Reply Share
Amazon does not sell any parts for the Echo devices. Your best and probably only alternative is to buy a used Echo from eBay and use this guide to repair it.
raymondjram - Reply Share
Can you get or buy replament mother boards for the ehco 5 ?
Shawn Haywood - Reply Share
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 150
All Time: 3,923
