Amazon Echo Dot 3rd Gen Disassembly
    1. Amazon Echo Dot 3rd Gen Disassembly, Removing The Base Plate: step 1, image 1 of 3 Amazon Echo Dot 3rd Gen Disassembly, Removing The Base Plate: step 1, image 2 of 3 Amazon Echo Dot 3rd Gen Disassembly, Removing The Base Plate: step 1, image 3 of 3
      • When Prying the bottom off, insert the Metal Spudger under the bottom where the ports are
      • Avoid letting the Adhesive touch anything, lay the plate on the branded side
      • If the adhesive is to strong use a hair dryer to soften it
      Ask FixBot
    2. Amazon Echo Dot 3rd Gen Disassembly, Removing Screws: step 2, image 1 of 3 Amazon Echo Dot 3rd Gen Disassembly, Removing Screws: step 2, image 2 of 3 Amazon Echo Dot 3rd Gen Disassembly, Removing Screws: step 2, image 3 of 3
      • Use a TORX T6H bit to remove the four screws on the bottom
      • When all the screws are taken out lift up and the covering should slide off
      Ask FixBot
    3. Amazon Echo Dot 3rd Gen Disassembly, Removing The First Mainboard: step 3, image 1 of 3 Amazon Echo Dot 3rd Gen Disassembly, Removing The First Mainboard: step 3, image 2 of 3 Amazon Echo Dot 3rd Gen Disassembly, Removing The First Mainboard: step 3, image 3 of 3
      • Remember to un latch the ribbon cable before pulling the circuit board up
      Ask FixBot
    4. Amazon Echo Dot 3rd Gen Disassembly, Removing the top: step 4, image 1 of 3 Amazon Echo Dot 3rd Gen Disassembly, Removing the top: step 4, image 2 of 3 Amazon Echo Dot 3rd Gen Disassembly, Removing the top: step 4, image 3 of 3
      • To get the further screws on the bottom, use a 4 mm nut driver and put the TORX bit in the nut driver as an extension
      • Pull up on the metal to release the top from the rest
      Ask FixBot
    5. Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top: step 5, image 1 of 3 Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top: step 5, image 2 of 3 Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top: step 5, image 3 of 3
      • Undo the four screws the remove the white defuser piece (I lost a screw)
      Ask FixBot
    6. Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top even further: step 6, image 1 of 2 Amazon Echo Dot 3rd Gen Disassembly, Disassembling the top even further: step 6, image 2 of 2
      • The two should separate if you hold the edge, if it doesn't push a button on top and it should pop out
      Ask FixBot
11 other people completed this guide.
Ben Nicholsonb
457 Reputation
1 Guide authored
3 Guide Comments
Parabéns pelo tutoria de desmontagem do aparelho ALEXA ECHO DOT 3ª geração! Excelente trabalho!!!
Eu recebi um aparelho desse para efetuar a manutenção, pois este estavatotalmente inoperante, por dois motivos:
1° ADAPTADOR FONTE AVARIADO, gerando tensão de saída DC oscilante;
2° MAL-CONTATO NO CABO FLEXÍVEL INTERNO que conecta as duas placas eletrônicas internas.
eduardosanchessales - Reply Share
How can I convert Amazon Echo Dot power from AC to DC?
Gift Sikufele - Reply Share
ciao, per caso sai indicarmi la parte specializzata per la rete wi-fi o segnali, ho un eco dot uguale e non viene rilevato in nessun modo per questo volevo vedere se ci fosse qualche problema al ricevitore wifi
Matteo Sala - Reply Share
Past 24 Hours: 20
Past 7 Days: 115
Past 30 Days: 456
All Time: 20,097
