Amazon Echo Dot 2nd Generation Ribbon Cable Replacement
  1. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement, Ribbon Cable: step 1, image 1 of 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement, Ribbon Cable: step 1, image 2 of 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement, Ribbon Cable: step 1, image 3 of 3
    • Power off and unplug the echo
    • Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
    Ask FixBot
  2. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: step 2, image 1 of 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: step 2, image 2 of 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: step 2, image 3 of 3
    • Use a T8 screwdriver bit to unscrew the 1.6mm four screws.
    • Remove the black cylindrical base
    Ask FixBot
  3. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: step 3, image 1 of 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: step 3, image 2 of 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: step 3, image 3 of 3
    • Use the metal spudger to lift the ZIF connector
    • Remove the ribbon cable from the slot
    Ask FixBot
  4. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: step 4, image 1 of 1
    • Remove the motherboard
    Ask FixBot
  5. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: step 5, image 1 of 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: step 5, image 2 of 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: step 5, image 3 of 3
    • Remove the silver divider
    • Remove the black rubber divider
    • Remove the plastic white frame
    Ask FixBot
  6. Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: step 6, image 1 of 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: step 6, image 2 of 3 Amazon Echo Dot 2nd Generation Ribbon Cable Replacement: step 6, image 3 of 3
    • Remove the ribbon cable from the slot on the LED/speaker board
    Ask FixBot
4 other people completed this guide.
Errica Snelling
772 Reputation
1 Guide authored
USF Tampa, Team S1-G3, Leahy Fall 2017 Member of USF Tampa, Team S1-G3, Leahy Fall 2017
USFT-LEAHY-F17S1G3
3 Members
12 Guides authored
5 Guide Comments
Where do you get the replacement cable from?
jonathan kabitzke - Reply Share
Yes, where can one get replacement ribbon cables?
Armando Morreale - Reply Share
Malcolm oakley - Reply Share
I need a replacement as well now was using a pointed tweezers when putting it back together and stabbed the cable need to find part and order from the uk
Barrie Gash - Reply Share
no cable available, just waiting for donors
Ray Floyd Cabrera - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 65
All Time: 3,194
