Up to 20% off select tools
Aluratek ADMPF310F Screen Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
6
Past 7 Days:
26
Past 30 Days:
103
All Time:
1,207
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Easy
Tools
  • iFixit Opening Tool
    4.8
  • Spudger
    4.9
Introduction
Go to step 1 ↓
This guide will walk you through how to replace the screen to your digital frame. This is one of the most simplest guides and doesn't take a lot of time at all.
    1. Aluratek ADMPF310F Screen Replacement, Screen: step 1, image 1 of 3 Aluratek ADMPF310F Screen Replacement, Screen: step 1, image 2 of 3 Aluratek ADMPF310F Screen Replacement, Screen: step 1, image 3 of 3
      • Using the plastic opening tool, pry off the clips all around the frame. You will hear a popping sound for every clip
      • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
      Ask FixBot
    2. Aluratek ADMPF310F Screen Replacement: step 2, image 1 of 1
      • Lift screen out of place so you can access the plugs that connect it.
      • Be careful not to pull the screen to far away when placing to the side, many fragile wires are connected.
      Ask FixBot
    3. Aluratek ADMPF310F Screen Replacement: step 3, image 1 of 2 Aluratek ADMPF310F Screen Replacement: step 3, image 2 of 2
      • Using the plastic spudger tool lift the plastic zif(zero instertion force) connector clip up.
      • Pull the ribbon cable away from the motherboard.
      • Be careful as this clip is very frail.
      Ask FixBot
    4. Aluratek ADMPF310F Screen Replacement: step 4, image 1 of 1
      • Disconnect the red and black cable connecting the screen to the motherboard by just pulling it out.
      Ask FixBot
Author
with
Chris Belair
333 Reputation
2 Guides authored
UMass Dartmouth, Team 5-1, Martin Fall 2016 Member of UMass Dartmouth, Team 5-1, Martin Fall 2016
UMASSD-MARTIN-F16S5G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 26
Past 30 Days: 103
All Time: 1,207
