Aluratek ADMPF310F Replacing USB Port Replacement
    1. Aluratek ADMPF310F Replacing USB Port Replacement, Motherboard: step 1, image 1 of 3 Aluratek ADMPF310F Replacing USB Port Replacement, Motherboard: step 1, image 2 of 3 Aluratek ADMPF310F Replacing USB Port Replacement, Motherboard: step 1, image 3 of 3
      • Using the black nylon spudger, pry off the clips all around the frame. You will hear a popping sound for every clip
      • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
      Ask FixBot
    2. Aluratek ADMPF310F Replacing USB Port Replacement: step 2, image 1 of 1
      • Lift screen out of place so you can access the plugs that connect it.
      Ask FixBot
    3. Aluratek ADMPF310F Replacing USB Port Replacement: step 3, image 1 of 2 Aluratek ADMPF310F Replacing USB Port Replacement: step 3, image 2 of 2
      • Using the plastic spudger tool lift the plastic zif(zero instertion force) connector clip up.
      • Pull the ribbon cable away from the mother board.
      • Be careful as this zif connector is very frail plastic.
      Ask FixBot
    4. Aluratek ADMPF310F Replacing USB Port Replacement: step 4, image 1 of 1
      • Disconnect the red and black cable connecting the screen to the motherboard by just pulling it out.
      Ask FixBot
    5. Aluratek ADMPF310F Replacing USB Port Replacement: step 5, image 1 of 1
      • Pull out remote receiver out of its clip.
      • Be careful to not move the wires around for the remote receiver too much, as they are soldered to the motherboard.
      Ask FixBot
    6. Aluratek ADMPF310F Replacing USB Port Replacement: step 6, image 1 of 2 Aluratek ADMPF310F Replacing USB Port Replacement: step 6, image 2 of 2
      • Using fingers pull the first speaker wire that is located closest to the speakers
      • Again using your fingers, pull out the second speaker wire near the far side of the motherboard.
      Ask FixBot
    7. Aluratek ADMPF310F Replacing USB Port Replacement: step 7, image 1 of 3 Aluratek ADMPF310F Replacing USB Port Replacement: step 7, image 2 of 3 Aluratek ADMPF310F Replacing USB Port Replacement: step 7, image 3 of 3
      • Using the ph0 phillips head screwdriver unscrew the four 4mm screws circled in the picture.
      Ask FixBot
    8. Aluratek ADMPF310F Replacing USB Port Replacement: step 8, image 1 of 1
      • Pull up the smaller end of the motherboard.
      • Apply force pulling away from the USB ports to get the mother board out of place.
      Ask FixBot
    1. Aluratek ADMPF310F Replacing USB Port Replacement, USB Port: step 9, image 1 of 1
      • On the back end of the mother board unsolder the USB port at the two points shown.
      Ask FixBot
Pascal Alexis
427 Reputation
3 Guides authored
UMass Dartmouth, Team 5-1, Martin Fall 2016 Member of UMass Dartmouth, Team 5-1, Martin Fall 2016
UMASSD-MARTIN-F16S5G1
3 Members
58 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 25
All Time: 546
