Up to 20% off select tools
Aluratek ADMPF310F Remote Sensor Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
25
Past 30 Days:
95
All Time:
770
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
In this guide you will learn how to remove and replace the remote sensor in your digital frame. Replacing the remote sensor fixes many common issues if your remote isn't working with your device. This guide also requires soldering for more on how to solder check the link here.
    1. Aluratek ADMPF310F Remote Sensor Replacement, Screen: step 1, image 1 of 3 Aluratek ADMPF310F Remote Sensor Replacement, Screen: step 1, image 2 of 3 Aluratek ADMPF310F Remote Sensor Replacement, Screen: step 1, image 3 of 3
      • Using the plastic opening tool, pry off the clips all around the frame. You will hear a popping sound for every clip
      • Be sure not to pry to hard because you could crack or break the plastic facing of the device.
      Ask FixBot
    2. Aluratek ADMPF310F Remote Sensor Replacement: step 2, image 1 of 1
      • Lift screen out of place so you can access the plugs that connect it.
      • Be careful not to pull the screen to far away when placing to the side, many fragile wires are connected.
      Ask FixBot
    3. Aluratek ADMPF310F Remote Sensor Replacement: step 3, image 1 of 2 Aluratek ADMPF310F Remote Sensor Replacement: step 3, image 2 of 2
      • Using the plastic spudger tool lift the plastic zif(zero instertion force) connector clip up.
      • Pull the ribbon cable away from the motherboard.
      • Be careful as this clip is very frail.
      Ask FixBot
    4. Aluratek ADMPF310F Remote Sensor Replacement: step 4, image 1 of 1
      • Disconnect the red and black cable connecting the screen to the motherboard by just pulling it out.
      Ask FixBot
    1. Aluratek ADMPF310F Remote Sensor Replacement, Remote Sensor: step 5, image 1 of 1
      • Pull out the remote sensor from its holder with your hands.
      • Unsolder the remote sensor from the motherboard.
      Ask FixBot
    2. Aluratek ADMPF310F Remote Sensor Replacement: step 6, image 1 of 1
      • Resolder the the remote sensor back to the motherboard.
      • For more on how to solder check the link here.
      Ask FixBot
Author
with
Pascal Alexis
427 Reputation
3 Guides authored
UMass Dartmouth, Team 5-1, Martin Fall 2016 Member of UMass Dartmouth, Team 5-1, Martin Fall 2016
UMASSD-MARTIN-F16S5G1
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 25
Past 30 Days: 95
All Time: 770
