Up to 20% off select tools
Aluminum Profile Frame Assembly
Views: 1.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
46
Past 30 Days:
210
All Time:
1,799
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 hours
Difficulty: Moderate
Community-Contributed Guide
    1. Aluminum Profile Frame Assembly, Preparing the Tools: step 1, image 1 of 1
      • Battery-Powered Drill
      • Steel Angle
      • T40 Bit
      • Ruler
      • Allen Wrench
      • Screw Clamp
      Ask FixBot
    2. Aluminum Profile Frame Assembly, Preparing the Aluminum Profile and Connectors - Part 1: step 2, image 1 of 1
      • 8 x hammer nuts B-type nut 8 [M6]
      • 8 x T-diaphragm connectors for 8 x M6x35 cylinder screws
      • 2 x 320mm aluminum profile 30 B-type nuts 8
      • 2 x 360mm aluminum profile 30 B-type nuts 8
      Ask FixBot
    3. Aluminum Profile Frame Assembly, Screwing Connectors Into the Aluminum Profile: step 3, image 1 of 3 Aluminum Profile Frame Assembly, Screwing Connectors Into the Aluminum Profile: step 3, image 2 of 3 Aluminum Profile Frame Assembly, Screwing Connectors Into the Aluminum Profile: step 3, image 3 of 3
      • Clamp the aluminum profile and use the drill to screw a connector into it clockwise. Use a T40 bit for this.
      • Screw 2 connectors into each of the opposite grooves.
      • Important: Before the connectors on the other side are screwed in, insert the included screws into the groove.
      • Screw-in two connectors in the same groove on the other end of the profile.
      Ask FixBot
    4. Aluminum Profile Frame Assembly, Aluminum Profile Assembly: step 4, image 1 of 3 Aluminum Profile Frame Assembly, Aluminum Profile Assembly: step 4, image 2 of 3 Aluminum Profile Frame Assembly, Aluminum Profile Assembly: step 4, image 3 of 3
      • Attach slot nuts to the screws on the aluminum profile (320mm) and slide them into the larger (360mm) aluminum profile.
      • With the help of another aluminum profile (size doesn't matter) and a screw clamp, attach the smaller aluminum profile to the "helper profile".
      • Slide the larger aluminum profile at a right angle into both of the other profiles.
      • Tighten the screws of the connectors with the 5mm Allen wrench.
      Ask FixBot
    5. Aluminum Profile Frame Assembly, Creating a Square: step 5, image 1 of 1
      • Repeat "Step 4" four times with the 4 aluminum profiles to create a square.
      • Use the right angle tool to check and make sure there is a right angle.
      Ask FixBot
    6. Aluminum Profile Frame Assembly, Preparing the Aluminum Profile and Connectors - Part 2: step 6, image 1 of 1
      • 2 x 330mm aluminum profile 30 B-type nuts 8
      • 1 x 360mm aluminum profile 30 B-type nuts 8
      Ask FixBot
    7. Aluminum Profile Frame Assembly, Screwing Connectors Into the Aluminum Profile - Part 2: step 7, image 1 of 2 Aluminum Profile Frame Assembly, Screwing Connectors Into the Aluminum Profile - Part 2: step 7, image 2 of 2
      • Screw-in two connectors in the other groove on the other end of the profile.
      • The connectors at the top and bottom of the profile are not in the same groove.
      Ask FixBot
    8. Aluminum Profile Frame Assembly, Creating a U-Shape: step 8, image 1 of 1
      • Repeat the instructions for step 4 and create a U-Shape.
      • Check that there is a right angle with the angle tool.
      Ask FixBot
    9. Aluminum Profile Frame Assembly, Connecting the Square and U-Shape: step 9, image 1 of 2 Aluminum Profile Frame Assembly, Connecting the Square and U-Shape: step 9, image 2 of 2
      • Place the U-Shape at 114mm
      • Fasten the helper profile to the aluminum profile with screw clamps.
      • Repeat the whole thing on the other side.
      • Use the steel angle to check if there is a right angle.
      Ask FixBot
The aluminum profile frame is now fully assembled.
Special thanks to these translators:
de en
100%
Brian IHLE (ILL) is helping us fix the world! Want to contribute?
Start translating ›
Author
with
Priscilla Schlageter
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 46
Past 30 Days: 210
All Time: 1,799
