This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Community-Contributed Guide
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓Replace the SSD in your Altyk le Petit PC.
Tools
First, unplug your machine from the power outlet, then turn it over and locate the 4 screws in the 4 corners underneath the machine. The screws are Phillips; you will need a screwdriver with a long shaft.
The SSD is an M.2 NVMe 2280 form factor. The original is 480 GB. To do this, you need to unscrew the screw holding it in place; the SSD will lift up on its own and you will be able to remove it. Simply replace it with the new one in the same way.
All you have to do is reassemble everything, and you're done :)
To reassemble your device, follow the instructions in reverse order.
