This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Introduction
Replacing a RAM module on an Altyk L16 laptop
Remove the 8 screws from the bottom of the PC (all screws are identical).
Slide an opening pick between the black plastic grille hidden behind the hinge cover. You can then slide it all the way along the plate to undo all the plastic snap fits.
Locate the battery connector.
Using plastic or ceramic tweezers, separate the connector from the motherboard using the corners of the connector as indicated in red.
Lift the battery wires to finish completely removing the battery from its connector.
Locate the RAM sticks; they are hidden under protective plastic covers.
Lift the plastic film to see the RAM.
Move the metal clips holding the RAM stick out of the way to release it.
Once your RAM stick is lifted as shown in the second photo, you can remove it. To install the new one, simply perform the same steps in reverse order.
To reassemble your device, follow the instructions in reverse order.
