This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Community-Contributed Guide
Introduction
Go to step 1 ↓Replacing the SSD on an Altyk L14 laptop.
Remove the 8 screws from the bottom of the PC (all screws are identical).
Slide an opening pick between the black plastic grille hidden behind the hinge cover. You can then slide it all the way along the plate to undo all the plastic snap fits.
Locate the battery connector.
Using plastic or ceramic tweezers, separate the connector from the motherboard using the corners of the connector as indicated in red.
Lift the battery wires to finish completely removing the battery from its connector.
Locate the SSD.
Remove the screw securing the SSD.
Once the SSD is angled as shown in the second photo, grab it by the end and pull it out of its connector. Install the new one by following the guide in reverse order and you are done!
To reassemble your device, follow the instructions in reverse order.
