This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Altyk Le PC portable L16 Battery Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
62
All Time:
153
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Replacing the battery on the Altyk L16 laptop
    1. Altyk Le PC portable L16 Battery Replacement, Remove the machine cover: step 1, image 1 of 3 Altyk Le PC portable L16 Battery Replacement, Remove the machine cover: step 1, image 2 of 3 Altyk Le PC portable L16 Battery Replacement, Remove the machine cover: step 1, image 3 of 3
      • Remove the 8 screws from the bottom of the PC (all screws are identical).
      • Slide an opening pick between the black plastic grille hidden behind the hinge cover. You can then slide it all the way along the plate to undo all the plastic snap fits.
      Ask FixBot
    2. Altyk Le PC portable L16 Battery Replacement, Disconnect the battery: step 2, image 1 of 1
      • Locate the battery connector.
      • Using plastic or ceramic tweezers, separate the connector from the motherboard using the corners of the connector as indicated in red.
      • Lift the battery wires to finish completely removing the battery from its connector.
      Ask FixBot
    1. Altyk Le PC portable L16 Battery Replacement, Remove the screws and the battery: step 3, image 1 of 1
      • Remove the 5 screws securing the battery. You can then grab the battery connector and lift it up to remove it.
      • You can now install the new battery and follow the steps in reverse order to reassemble the machine.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
INFOREA
4,931 Reputation
38 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 62
All Time: 153
