This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Altyk L16 Laptop BIOS Battery Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
69
All Time:
142
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 4 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
Replacement of the BIOS battery for the Altyk L16 laptop.
    1. Altyk L16 Laptop BIOS Battery Replacement, Remove the machine cover: step 1, image 1 of 3 Altyk L16 Laptop BIOS Battery Replacement, Remove the machine cover: step 1, image 2 of 3 Altyk L16 Laptop BIOS Battery Replacement, Remove the machine cover: step 1, image 3 of 3
      • Remove the 8 screws from the bottom of the PC (all screws are identical).
      • Slide an opening pick between the black plastic grille hidden behind the hinge cover. You can then slide it all the way along the plate to undo all the plastic snap fits.
      Ask FixBot
    2. Altyk L16 Laptop BIOS Battery Replacement, Disconnect the battery: step 2, image 1 of 1
      • Locate the battery connector.
      • Using plastic or ceramic tweezers, separate the connector from the motherboard using the corners of the connector as indicated in red.
      • Lift the battery wires to finish completely removing the battery from its connector.
      Ask FixBot
    1. Altyk L16 Laptop BIOS Battery Replacement, Remove the BIOS battery: step 3, image 1 of 2 Altyk L16 Laptop BIOS Battery Replacement, Remove the BIOS battery: step 3, image 2 of 2
      • Locate the BIOS battery
      • Disconnect the BIOS battery from the motherboard
      • Detach the BIOS battery from the machine's frame
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
INFOREA
4,931 Reputation
38 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 69
All Time: 142
