Alternator Replacement
    1. Alternator Replacement, Remove bolts and wire: step 1, image 1 of 3 Alternator Replacement, Remove bolts and wire: step 1, image 2 of 3 Alternator Replacement, Remove bolts and wire: step 1, image 3 of 3
      • Push the metal tab closest to the black wire down. While pushing the tab down, pull the black wire out of the clip.
      • Using a 1/4 socket, remove the two bolts holding the alternator to the engine.
      • From the alternator side, gently pull the black wire out past the cylinder it is routed under on the engine.
      Ask FixBot
2 other people completed this guide.
Jacob Micallef
1,023 Reputation
7 Guides authored
1 Guide Comment
it's so good
Galatea - Reply Share
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 35
All Time: 793
