Altec Lansing inMotion iM9 Tweeter Replacement
    1. Altec Lansing inMotion iM9 Tweeter Replacement, Battery: step 1, image 1 of 1
      • Gently push down on the two tabs at the top of the battery door.
      • While holding them down, slowly pull the door towards you.
      Ask FixBot
    2. Altec Lansing inMotion iM9 Tweeter Replacement: step 2, image 1 of 1
      • Once the door is open, use your hand to pull out the four batteries.
      Ask FixBot
    1. Altec Lansing inMotion iM9 Tweeter Replacement, Volume and Power Buttons: step 3, image 1 of 2 Altec Lansing inMotion iM9 Tweeter Replacement, Volume and Power Buttons: step 3, image 2 of 2
      • Pry off the control panel on top of the speaker using the metal spudger. You may need to use a lot of force.
      • Start in the middle and work your way around the perimeter.
      Ask FixBot
    2. Altec Lansing inMotion iM9 Tweeter Replacement: step 4, image 1 of 2 Altec Lansing inMotion iM9 Tweeter Replacement: step 4, image 2 of 2
      • Using a Phillips #1 screwdriver, remove the two 7mm screws that hold the volume button circuit board to the control panel.
      • Also remove the single 7mm screw from the power button circuit board on the opposite side.
      • There will be a little plastic piece under the eject button that you can just remove and set aside.
      Ask FixBot
    3. Altec Lansing inMotion iM9 Tweeter Replacement: step 5, image 1 of 2 Altec Lansing inMotion iM9 Tweeter Replacement: step 5, image 2 of 2
      • Desolder the three solders joints connecting the wires to the volume button circuit board.
      • Do the same to the power button circuit board on the other side (the board with only one screw).
      • Pull out the wires using a lot of force.
      • If you are not familiar or comfortable with soldering, use this guide
      Ask FixBot
    1. Altec Lansing inMotion iM9 Tweeter Replacement, Case Opening: step 6, image 1 of 2 Altec Lansing inMotion iM9 Tweeter Replacement, Case Opening: step 6, image 2 of 2
      • Gently pry open the silver plastic lining of the iPod dock using the plastic spudger.
      • It is best to start from the top or bottom, then work your way around if it has not popped out yet.
      • Remove the silver lining.
      Ask FixBot
    2. Altec Lansing inMotion iM9 Tweeter Replacement: step 7, image 1 of 2 Altec Lansing inMotion iM9 Tweeter Replacement: step 7, image 2 of 2
      • Pry open the metal mesh by working the plastic spudger around the inside of the mesh.
      • Once loose, lift up the metal mesh.
      Ask FixBot
    3. Altec Lansing inMotion iM9 Tweeter Replacement: step 8, image 1 of 1
      • Remove the fourteen 30mm screws with Phillips #1 Screwdriver.
      • Remove the 7mm screw with the Phillips #1 Screwdriver.
      Ask FixBot
    4. Altec Lansing inMotion iM9 Tweeter Replacement: step 9, image 1 of 1
      • Carefully separate the front and back case plates at a corner of the speaker.
      • Lots of cables are still connected, so be very gentle when separating case plates.
      Ask FixBot
    5. Altec Lansing inMotion iM9 Tweeter Replacement: step 10, image 1 of 1
      • Guide the white button cables through the hole on the top of speaker case.
      Ask FixBot
    6. Altec Lansing inMotion iM9 Tweeter Replacement: step 11, image 1 of 1
      • Use your fingers to peel the glue off of the red and black cables.
      Ask FixBot
    7. Altec Lansing inMotion iM9 Tweeter Replacement: step 12, image 1 of 1
      • Careful not to touch the green capacitors or you might shock yourself.
      Ask FixBot
    1. Altec Lansing inMotion iM9 Tweeter Replacement, Tweeter: step 13, image 1 of 1
      • Remove the speaker cables by desoldering the two solder joints on opposite sides of the tweeter.
      Ask FixBot
    2. Altec Lansing inMotion iM9 Tweeter Replacement: step 14, image 1 of 1
      • To fully remove the tweeter from the device, unscrew the two 7mm screws and the tweeter will be free.
      Ask FixBot
    3. Altec Lansing inMotion iM9 Tweeter Replacement: step 15, image 1 of 1
      • Follow the previous instructions to remove the second tweeter on the opposite side of the speaker.
      Ask FixBot
Shaun Steele
279 Reputation
2 Guides authored
Cal Poly, Team 17-33, Amido Winter 2015 Member of Cal Poly, Team 17-33, Amido Winter 2015
CPSU-AMIDO-W15S17G33
4 Members
84 Guides authored
1 Guide Comment
Where do you buy the replacement tweeters?
Fred Schneider - Reply Share
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 26
All Time: 1,355
