Altec Lansing VersA Smart Bluebooth Board Replacement
  1. Altec Lansing VersA Smart Bluebooth Board Replacement, External Panels: step 1, image 1 of 1
    • Remove external rubber cover.
    Ask FixBot
  2. Altec Lansing VersA Smart Bluebooth Board Replacement: step 2, image 1 of 2 Altec Lansing VersA Smart Bluebooth Board Replacement: step 2, image 2 of 2
    • Use blue plastic opening tool to remove the external speaker face by placing it in the slight opening at the bottom.
    • Use a lever motion, push the tool down, lifting the speaker face.
    • Use fingers to grip and remove speaker face.
    • Repeat on reverse side to remove the second speaker face.
    Ask FixBot
  3. Altec Lansing VersA Smart Bluebooth Board Replacement: step 3, image 1 of 2 Altec Lansing VersA Smart Bluebooth Board Replacement: step 3, image 2 of 2
    • Orient speaker so volume buttons are facing away from you, and Bluetooth and power buttons are on the left-hand side.
    • Remove the seven 14mm screws using the Phillips #1 screwdriver.
    Ask FixBot
  4. Altec Lansing VersA Smart Bluebooth Board Replacement: step 4, image 1 of 1
    • Reorient speaker so Bluetooth and power buttons are now on the right-hand side.
    • Separate the two panels along the crease.
    • Blue plastic opening tool may be needed to separate panels.
    • Remove the panel with no buttons to expose internal area of the device.
    • Motherboard and all internal components are under this panel.
    Ask FixBot
  5. Altec Lansing VersA Smart Bluebooth Board Replacement, Bluebooth Board: step 5, image 1 of 1
    • Detach the wiring piece, located in the upper right corner of the motherboard.
    Ask FixBot
  6. Altec Lansing VersA Smart Bluebooth Board Replacement: step 6, image 1 of 2 Altec Lansing VersA Smart Bluebooth Board Replacement: step 6, image 2 of 2
    • Remove the daughterboard piece from its designated slot, located to the right of the motherboard.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 33
All Time: 989
