Altec Lansing Mini Lifejacket 2 Speaker Replacement
  1. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: step 1, image 1 of 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: step 1, image 2 of 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement, Back Panel: step 1, image 3 of 3
    • Use the spudger to remove the eight black pins from the front and back of the wire screens.
    Ask FixBot
  2. Altec Lansing Mini Lifejacket 2 Speaker Replacement: step 2, image 1 of 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: step 2, image 2 of 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: step 2, image 3 of 3
    • Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
    • Removing the secondary pins from the rubber casing is optional.
    Ask FixBot
  3. Altec Lansing Mini Lifejacket 2 Speaker Replacement: step 3, image 1 of 2 Altec Lansing Mini Lifejacket 2 Speaker Replacement: step 3, image 2 of 2
    • Remove both black and orange layers from the speaker body.
    Ask FixBot
  4. Altec Lansing Mini Lifejacket 2 Speaker Replacement: step 4, image 1 of 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: step 4, image 2 of 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: step 4, image 3 of 3
    • Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
    • Slide the mounting plate out to remove it.
    Ask FixBot
  5. Altec Lansing Mini Lifejacket 2 Speaker Replacement: step 5, image 1 of 2 Altec Lansing Mini Lifejacket 2 Speaker Replacement: step 5, image 2 of 2
    • Pry off the wire mesh on both sides using a metal spudger.
    • Be gentle to avoid bending the mesh.
    Ask FixBot
  6. Altec Lansing Mini Lifejacket 2 Speaker Replacement: step 6, image 1 of 2 Altec Lansing Mini Lifejacket 2 Speaker Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
    Ask FixBot
  7. Altec Lansing Mini Lifejacket 2 Speaker Replacement: step 7, image 1 of 1
    • Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
    Ask FixBot
  8. Altec Lansing Mini Lifejacket 2 Speaker Replacement: step 8, image 1 of 1
    • Pull the case apart to access the interior components.
    Ask FixBot
  9. Altec Lansing Mini Lifejacket 2 Speaker Replacement: step 9, image 1 of 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: step 9, image 2 of 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: step 9, image 3 of 3
    • To remove the back panel, gently pull out its wire harness.
    Ask FixBot
  10. Altec Lansing Mini Lifejacket 2 Speaker Replacement, Speaker: step 10, image 1 of 2 Altec Lansing Mini Lifejacket 2 Speaker Replacement, Speaker: step 10, image 2 of 2
    • Remove the three 9.3 mm Phillips #1 screws on the speaker cover.
    Ask FixBot
  11. Altec Lansing Mini Lifejacket 2 Speaker Replacement: step 11, image 1 of 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: step 11, image 2 of 3 Altec Lansing Mini Lifejacket 2 Speaker Replacement: step 11, image 3 of 3
    • To remove the speaker, gently pull out the its wire harness.
    Ask FixBot
  12. Altec Lansing Mini Lifejacket 2 Speaker Replacement: step 12, image 1 of 2 Altec Lansing Mini Lifejacket 2 Speaker Replacement: step 12, image 2 of 2
    • Remove the rubber ring from the rim of the speaker.
    • This ring helps keep water from entering the device. Be careful to position it correctly during reassembly.
    Ask FixBot
Stephen Albrecht
1,053 Reputation
4 Guides authored
USF Tampa, Team S3-G2, Nance Spring 2018 Member of USF Tampa, Team S3-G2, Nance Spring 2018
USFT-NANCE-S18S3G2
4 Members
4 Guides authored
3 Guide Comments
What speaker should we be getting to replace the faulty speaker, including the wires needed to plug into the slots on the board?
russell rogge - Reply Share
Where can I get this speaker parts?
T Rex movies - Reply Share
Where can I get a complete power circuit board from for a Imw575 as mine is completely broken thank you
Paul Williams - Reply Share
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 53
All Time: 4,976
