Altec Lansing Mini Lifejacket 2 Motherboard Replacement
  1. Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Back Panel: step 1, image 1 of 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Back Panel: step 1, image 2 of 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Back Panel: step 1, image 3 of 3
    • Use the spudger to remove the eight black pins from the front and back of the wire screens.
    Ask FixBot
  2. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: step 2, image 1 of 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: step 2, image 2 of 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: step 2, image 3 of 3
    • Detach the eight secondary pins from the front and back of the wire mesh plates with a spudger.
    • Removing the secondary pins from the rubber casing is optional.
    Ask FixBot
  3. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: step 3, image 1 of 2 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: step 3, image 2 of 2
    • Remove both black and orange layers from the speaker body.
    Ask FixBot
  4. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: step 4, image 1 of 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: step 4, image 2 of 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: step 4, image 3 of 3
    • Remove the single 7.8mm Phillips #2 screw from the mounting plate located under the device.
    • Slide the mounting plate out to remove it.
    Ask FixBot
  5. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: step 5, image 1 of 2 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: step 5, image 2 of 2
    • Pry off the wire mesh on both sides using a metal spudger.
    • Be gentle to avoid bending the mesh.
    Ask FixBot
  6. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: step 6, image 1 of 2 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Using tweezers, remove the four rubber stoppers in each corner of the rear panel.
    Ask FixBot
  7. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: step 7, image 1 of 1
    • Remove the four 13.7mm Phillips #1 screws located underneath the rubber stoppers.
    Ask FixBot
  8. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: step 8, image 1 of 1
    • Pull the case apart to access the interior components.
    Ask FixBot
  9. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: step 9, image 1 of 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: step 9, image 2 of 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: step 9, image 3 of 3
    • To remove the back panel, gently pull out its wire harness.
    Ask FixBot
  10. Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Battery: step 10, image 1 of 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Battery: step 10, image 2 of 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Battery: step 10, image 3 of 3
    • Disconnect the battery from the motherboard.
    • The battery is not secured within the case and can be removed after detaching its wiring from the circuit board.
    Ask FixBot
  11. Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Motherboard: step 11, image 1 of 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Motherboard: step 11, image 2 of 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement, Motherboard: step 11, image 3 of 3
    • Unplug the remaining four wire harnesses attached to the circuit board
    Ask FixBot
  12. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: step 12, image 1 of 2 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: step 12, image 2 of 2
    • Remove the three 9.1mm Phillips #1 screws located on the circuit board.
    Ask FixBot
  13. Altec Lansing Mini Lifejacket 2 Motherboard Replacement: step 13, image 1 of 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: step 13, image 2 of 3 Altec Lansing Mini Lifejacket 2 Motherboard Replacement: step 13, image 3 of 3
    • Remove the motherboard.
    Ask FixBot
2 other people completed this guide.
Stephen Albrecht
1,053 Reputation
4 Guides authored
USF Tampa, Team S3-G2, Nance Spring 2018 Member of USF Tampa, Team S3-G2, Nance Spring 2018
USFT-NANCE-S18S3G2
4 Members
4 Guides authored
6 Guide Comments
I own the IMW778-BLU-TA model. Where can I find a replacement motherboard for it??
Nick Cote - Reply Share
same for me, anyone knows where can I find a replacement of the motherboard? thx
Travis - Reply Share
need back panel replacement
rahul pande - Reply Share
Same here! Loved the product. Can not afford to buy something else.
Mr Shopper - Reply Share
I need 2 the board for charging,usb,aux cord that plugs into motherboard.
John Proffit - Reply Share
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 50
All Time: 6,347
