Altec Lansing BoomJacket Speaker Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
83
All Time:
1,378
Comments: 2
2 guide comments.
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Are your speakers not producing the same amount of BOOM that they used to? Perhaps repairing your speakers is the way to go.
Parts
Tools
    1. Altec Lansing BoomJacket Speaker Replacement, Speaker: step 1, image 1 of 1
      • Using your hands, remove the pegs (4+4) from the front and back of the speaker.
      Ask FixBot
    2. Altec Lansing BoomJacket Speaker Replacement: step 2, image 1 of 1
      • Remove the outer black rubber housing of the speaker.
      Ask FixBot
    3. Altec Lansing BoomJacket Speaker Replacement: step 3, image 1 of 1
      • Remove the inner blue rubber housing from the speaker.
      Ask FixBot
    4. Altec Lansing BoomJacket Speaker Replacement: step 4, image 1 of 1
      • Pull out the two black wire meshes using a metal spudger.
      • Be careful not to damage the metal casing.
      Ask FixBot
    5. Altec Lansing BoomJacket Speaker Replacement: step 5, image 1 of 2 Altec Lansing BoomJacket Speaker Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
      Ask FixBot
    6. Altec Lansing BoomJacket Speaker Replacement: step 6, image 1 of 1
      • Using the size PH1 screwdriver remove the screws (4 around each speaker).
      Ask FixBot
    7. Altec Lansing BoomJacket Speaker Replacement: step 7, image 1 of 1
      • Pull the case apart and you will be able to see all the components inside the speaker.
      Ask FixBot
    8. Altec Lansing BoomJacket Speaker Replacement: step 8, image 1 of 1
      • Remove the speakers (not entirely because of the wiring) by gently pulling each speaker up.
      Ask FixBot
2 Guide Comments
Where do I find the correct part to replace the charging port on my boom jacket?
Rockstar - Reply Share
1.1" External Magnetic Type Round Slim Plastic Shell Speaker 8 Ohm 0.25W 2 Pcs
Eeshton - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 83
All Time: 1,378
