Up to 20% off select tools
Altec Lansing BoomJacket Power Button Replacement
Views: 22K
View statistics:
Past 24 Hours:
3
Past 7 Days:
19
Past 30 Days:
100
All Time:
21,689
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Will your device not turn on or off? Your power button is likely the reason.
    1. Altec Lansing BoomJacket Power Button Replacement, Case Removal: step 1, image 1 of 1
      • Using your hands, remove the pegs (4+4) from the front and back of the speaker.
      Ask FixBot
    2. Altec Lansing BoomJacket Power Button Replacement: step 2, image 1 of 1
      • Remove the outer black rubber housing of the speaker.
      Ask FixBot
    3. Altec Lansing BoomJacket Power Button Replacement: step 3, image 1 of 1
      • Remove the inner blue rubber housing from the speaker.
      Ask FixBot
    4. Altec Lansing BoomJacket Power Button Replacement: step 4, image 1 of 1
      • Pull out the two black wire meshes using a metal spudger.
      • Be careful not to damage the metal casing.
      Ask FixBot
    5. Altec Lansing BoomJacket Power Button Replacement: step 5, image 1 of 2 Altec Lansing BoomJacket Power Button Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
      Ask FixBot
    6. Altec Lansing BoomJacket Power Button Replacement: step 6, image 1 of 1
      • Using the size PH1 screwdriver remove the screws exposed from the rubber stoppers (4 + 2).
      Ask FixBot
    7. Altec Lansing BoomJacket Power Button Replacement: step 7, image 1 of 1
      • Pull the case apart and you will be able to see all the components inside the speaker.
      Ask FixBot
    1. Altec Lansing BoomJacket Power Button Replacement, Power Button: step 8, image 1 of 1
      • The battery will be sitting right behind the speakers when the case is open.
      Ask FixBot
    2. Altec Lansing BoomJacket Power Button Replacement: step 9, image 1 of 2 Altec Lansing BoomJacket Power Button Replacement: step 9, image 2 of 2
      • Unplug and disconnect the battery from the motherboard.
      Ask FixBot
    3. Altec Lansing BoomJacket Power Button Replacement: step 10, image 1 of 1
      • Using a size PH1 screwdriver, remove the two screws.
      Ask FixBot
    4. Altec Lansing BoomJacket Power Button Replacement: step 11, image 1 of 2 Altec Lansing BoomJacket Power Button Replacement: step 11, image 2 of 2
      • You will now see the motherboard for the power button.
      • Remove the 2 screws holding the motherboard into place.
      Ask FixBot
    5. Altec Lansing BoomJacket Power Button Replacement: step 12, image 1 of 1
      • Pick up the motherboard and take it out of the slot.
      Ask FixBot
    6. Altec Lansing BoomJacket Power Button Replacement: step 13, image 1 of 1
      • Disconnect the power button motherboard from the speaker motherboard.
      Ask FixBot
8 other people completed this guide.
Author
with
Ryan Byrnes
872 Reputation
5 Guides authored
1 Guide Comment
Current speaker won’t turn on even though charging light looks all good so came across these instructions.
Thinking it’s the power button on my speaker that’s the issue.
Assuming these instructions are assuming you are replacing the power button motherboard? Where could I source one?
Cat Moure - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 100
All Time: 21,689
