Up to 20% off select tools
Altec Lansing BoomJacket Battery Replacement
Views: 16K
View statistics:
Past 24 Hours:
6
Past 7 Days:
26
Past 30 Days:
113
All Time:
16,334
Comments: 11
5 comments on steps, 6 guide comments.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 20 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
Is your Altec Lansing BoomJacket having charging issues or will not charge at all? Replacing the battery may help.
    1. Altec Lansing BoomJacket Battery  Replacement, Case Removal: step 1, image 1 of 1
      • Using your hands, remove the pegs (4+4) from the front and back of the speaker.
      Ask FixBot
    2. Altec Lansing BoomJacket Battery  Replacement: step 2, image 1 of 1
      • Remove the outer black rubber housing of the speaker.
      Ask FixBot
    3. Altec Lansing BoomJacket Battery  Replacement: step 3, image 1 of 1
      • Remove the inner blue rubber housing from the speaker.
      Ask FixBot
    4. Altec Lansing BoomJacket Battery  Replacement: step 4, image 1 of 1
      • Pull out the two black wire meshes using a metal spudger.
      • Be careful not to damage the metal casing.
      Ask FixBot
    5. Altec Lansing BoomJacket Battery  Replacement: step 5, image 1 of 2 Altec Lansing BoomJacket Battery  Replacement: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers remove the rubber stoppers (4 at the back + 2 at the front).
      Ask FixBot
    6. Altec Lansing BoomJacket Battery  Replacement: step 6, image 1 of 1
      • Using the size PH1 screwdriver remove the screws exposed from the rubber stoppers (4 + 2).
      Ask FixBot
    7. Altec Lansing BoomJacket Battery  Replacement: step 7, image 1 of 1
      • Pull the case apart and you will be able to see all the components inside the speaker.
      Ask FixBot
    1. Altec Lansing BoomJacket Battery  Replacement, Battery: step 8, image 1 of 1
      • The battery will be sitting right behind the speakers when the case is open.
      Ask FixBot
    2. Altec Lansing BoomJacket Battery  Replacement: step 9, image 1 of 1
      • Unplug and disconnect the battery from the motherboard.
      Ask FixBot
5 other people completed this guide.
Author
with
Ryan Byrnes
872 Reputation
5 Guides authored
6 Guide Comments
Where can you buy a replacement battery?
Darrell riley - Reply Share
Where can you buy the battery please?
Juan Roa - Reply Share
Where can I find ghe batteries? What type of battery ?
Violet Roach - Reply Share
where ca i buy a replacement battery
Shelley Franck - Reply Share
This tutorial is incomplete.
Ivan Rodriguez - Reply Share
Past 24 Hours: 6
Past 7 Days: 26
Past 30 Days: 113
All Time: 16,334
