Up to 20% off select tools
Altec Lansing BoomJacket 2 Disassembly
Views: 2.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
73
All Time:
2,294
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 15 minutes
Difficulty: Moderate
Parts
Tools
Introduction
Go to step 1 ↓
After completing this guide you will be ready to repair or replace any of the components inside your device.
    1. Altec Lansing BoomJacket 2 Disassembly, Altec Lansing BoomJacket 2 Disassembly: step 1, image 1 of 2 Altec Lansing BoomJacket 2 Disassembly, Altec Lansing BoomJacket 2 Disassembly: step 1, image 2 of 2
      • Starting from any side, use your fingers to grab the black rubber sleeve and gently pull away from the speaker on both sides.
      Ask FixBot
    2. Altec Lansing BoomJacket 2 Disassembly: step 2, image 1 of 2 Altec Lansing BoomJacket 2 Disassembly: step 2, image 2 of 2
      • Using your fingers, grab the blue sleeve from one side and pull away from the unit.
      Ask FixBot
    3. Altec Lansing BoomJacket 2 Disassembly: step 3, image 1 of 1
      • At each of the marked pry spots, use the metal spudger to lift the speaker grill away from the case.
      • Avoid using excessive force to prevent bending the grill.
      Ask FixBot
    4. Altec Lansing BoomJacket 2 Disassembly: step 4, image 1 of 2 Altec Lansing BoomJacket 2 Disassembly: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use the tweezers to remove the six rubber stoppers. There are four in the middle and two on the sides.
      Ask FixBot
    5. Altec Lansing BoomJacket 2 Disassembly: step 5, image 1 of 1
      • Use the PH1 Phillips screwdriver to remove the six 12mm screws that lie underneath each rubber stopper.
      Ask FixBot
    6. Altec Lansing BoomJacket 2 Disassembly: step 6, image 1 of 1
      • Gently pull apart the front panel from the base of the speaker.
      Ask FixBot
3 other people completed this guide.
Author
with
Zach Braaten
561 Reputation
4 Guides authored
UW Tacoma, Team S1-G4, Cardinal Summer 2018 Member of UW Tacoma, Team S1-G4, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 73
All Time: 2,294
