Altec Lansing BoomJacket 2 Battery Replacement
    1. Altec Lansing BoomJacket 2 Battery Replacement, Altec Lansing BoomJacket 2 Disassembly: step 1, image 1 of 2 Altec Lansing BoomJacket 2 Battery Replacement, Altec Lansing BoomJacket 2 Disassembly: step 1, image 2 of 2
      • Starting from any side, use your fingers to grab the black rubber sleeve and gently pull away from the speaker on both sides.
      Ask FixBot
    2. Altec Lansing BoomJacket 2 Battery Replacement: step 2, image 1 of 2 Altec Lansing BoomJacket 2 Battery Replacement: step 2, image 2 of 2
      • Using your fingers, grab the blue sleeve from one side and pull away from the unit.
      Ask FixBot
    3. Altec Lansing BoomJacket 2 Battery Replacement: step 3, image 1 of 1
      • At each of the marked pry spots, use the metal spudger to lift the speaker grill away from the case.
      • Avoid using excessive force to prevent bending the grill.
      Ask FixBot
    4. Altec Lansing BoomJacket 2 Battery Replacement: step 4, image 1 of 2 Altec Lansing BoomJacket 2 Battery Replacement: step 4, image 2 of 2
      Tool used on this step:
      Buy
      • Use the tweezers to remove the six rubber stoppers. There are four in the middle and two on the sides.
      Ask FixBot
    5. Altec Lansing BoomJacket 2 Battery Replacement: step 5, image 1 of 1
      • Use the PH1 Phillips screwdriver to remove the six 12mm screws that lie underneath each rubber stopper.
      Ask FixBot
    6. Altec Lansing BoomJacket 2 Battery Replacement: step 6, image 1 of 1
      • Gently pull apart the front panel from the base of the speaker.
      Ask FixBot
    1. Altec Lansing BoomJacket 2 Battery Replacement, Battery: step 7, image 1 of 1
      • The battery will be in the middle of the speaker when the case is open.
      Ask FixBot
    2. Altec Lansing BoomJacket 2 Battery Replacement: step 8, image 1 of 1
      • Pull firmly from both sides of the pin to disconnect the battery cable from the motherboard.
      • Pull battery up and away from speaker without catching any other components.
      • Motherboards have fragile components and can easily be damaged if they are hit or pulled on while extracting other parts.
      Ask FixBot
2 other people completed this guide.
Zach Braaten
561 Reputation
4 Guides authored
UW Tacoma, Team S1-G4, Cardinal Summer 2018 Member of UW Tacoma, Team S1-G4, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 29
All Time: 2,098
