Altair WBP-210 Mini-XLR socket Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
13
Past 30 Days:
57
All Time:
381
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
    1. Altair WBP-210 Mini-XLR socket Replacement, Remove nut on mini-xlr connector: step 1, image 1 of 1
      • Remove the nut on the mini-xlr connector.
      Ask FixBot
    2. Altair WBP-210 Mini-XLR socket Replacement, Remove corner panels: step 2, image 1 of 1
      • Slide off rubber corner panels holding together the case.
      Ask FixBot
    3. Altair WBP-210 Mini-XLR socket Replacement, Remove case screws: step 3, image 1 of 1
      • If your device has additional screws holding the case together, remove those as well.
      • Not all devices have these screws.
      Ask FixBot
    4. Altair WBP-210 Mini-XLR socket Replacement, Open case: step 4, image 1 of 2 Altair WBP-210 Mini-XLR socket Replacement, Open case: step 4, image 2 of 2
      • Separate the two halves of the case using a suitable tool.
      • Pay attention to the ribbon cable connecting the two halves.
      • The top and bottom panels stay attached to the front of the case.
      Ask FixBot
    5. Altair WBP-210 Mini-XLR socket Replacement, Disconnect Auxiliary Board: step 5, image 1 of 2 Altair WBP-210 Mini-XLR socket Replacement, Disconnect Auxiliary Board: step 5, image 2 of 2
      • Disconnect the Auxiliary Board from the Main Board and put it aside.
      Ask FixBot
    6. Altair WBP-210 Mini-XLR socket Replacement, Remove battery: step 6, image 1 of 2 Altair WBP-210 Mini-XLR socket Replacement, Remove battery: step 6, image 2 of 2
      • Disconnect the battery connector.
      • Gently remove the strip of PCB holding the battery in place.
      Ask FixBot
    7. Altair WBP-210 Mini-XLR socket Replacement, Remove Main Board: step 7, image 1 of 3 Altair WBP-210 Mini-XLR socket Replacement, Remove Main Board: step 7, image 2 of 3 Altair WBP-210 Mini-XLR socket Replacement, Remove Main Board: step 7, image 3 of 3
      • The Main Board is held in place by four PH screws.
      • After removing the screws, gently slide the Main Board out of the main case, together with the top and bottom plates.
      Ask FixBot
    8. Altair WBP-210 Mini-XLR socket Replacement, Replace Mini-XLR4 connector: step 8, image 1 of 3 Altair WBP-210 Mini-XLR socket Replacement, Replace Mini-XLR4 connector: step 8, image 2 of 3 Altair WBP-210 Mini-XLR socket Replacement, Replace Mini-XLR4 connector: step 8, image 3 of 3
      • Desolder the defective connector.
      • It is held in place by 4 pins, no additional pads.
      • Matching replacement part is Switchcraft TRAPC4MSX
      • Amphenol AG4MPCH and Kuilong YA137-2 might fit too.
      • Re-solder the new connector.
      Ask FixBot
    9. Altair WBP-210 Mini-XLR socket Replacement, Assemble lower cover plate.: step 9, image 1 of 2 Altair WBP-210 Mini-XLR socket Replacement, Assemble lower cover plate.: step 9, image 2 of 2
      • Reassemble the lower cover plate.
      • Pay attention to the location of the washer.
      • Tighten the nut on new connector.
      Ask FixBot
When reassembling, take care to only connect the battery after connecting the Auxiliary Board.
raven
1,110 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 57
All Time: 381
