Altair WBP-210 Full Disassembly
    1. Altair WBP-210 Full Disassembly, Remove Mini-XLR nut: step 1, image 1 of 1
      • Remove nut on mini-XLR connector.
      Ask FixBot
    2. Altair WBP-210 Full Disassembly, Remove rubber panels: step 2, image 1 of 2 Altair WBP-210 Full Disassembly, Remove rubber panels: step 2, image 2 of 2
      • Slide off rubber panels on all four corners.
      • If there are screws underneath, remove those as well.
      Ask FixBot
    3. Altair WBP-210 Full Disassembly, Open case: step 3, image 1 of 2 Altair WBP-210 Full Disassembly, Open case: step 3, image 2 of 2
      • Open the case using a suitable tool to help separate the two halves.
      • Watch out for the ribbon cable.
      Ask FixBot
    4. Altair WBP-210 Full Disassembly, Remove back case.: step 4, image 1 of 2 Altair WBP-210 Full Disassembly, Remove back case.: step 4, image 2 of 2
      • Disconnect the back half of the case.
      Ask FixBot
    5. Altair WBP-210 Full Disassembly, Remove Auxiliary Board: step 5, image 1 of 2 Altair WBP-210 Full Disassembly, Remove Auxiliary Board: step 5, image 2 of 2
      • There are four screws holding the Auxiliary Board in place.
      Ask FixBot
    6. Altair WBP-210 Full Disassembly, Remove Battery: step 6, image 1 of 2 Altair WBP-210 Full Disassembly, Remove Battery: step 6, image 2 of 2
      • The battery is held in place by a flexible bit of PCB, which can be carefully removed.
      Ask FixBot
    7. Altair WBP-210 Full Disassembly, Remove main board: step 7, image 1 of 2 Altair WBP-210 Full Disassembly, Remove main board: step 7, image 2 of 2
      • The main PCB is held in place by four screws.
      Ask FixBot
raven
1,110 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 24
All Time: 350
