Up to 20% off select tools
AlphaSmart Pro Motherboard Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
92
All Time:
1,180
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. AlphaSmart Pro Motherboard Replacement, Separating Panels: step 1, image 1 of 3 AlphaSmart Pro Motherboard Replacement, Separating Panels: step 1, image 2 of 3 AlphaSmart Pro Motherboard Replacement, Separating Panels: step 1, image 3 of 3
      • Power off your AlphaSmart Pro device and remove the batteries before beginning disassembly.
      • Remove all eight 1 cm Phillips head screws from the back panel of the AlphaSmart Pro with the Phillips #00 Screwdriver.
      • Carefully separate the front panel from the back panel.
      • Notice that the front and back panels are still connected by a ribbon cable.
      Ask FixBot
    2. AlphaSmart Pro Motherboard Replacement, Detaching Ribbon Cable: step 2, image 1 of 3 AlphaSmart Pro Motherboard Replacement, Detaching Ribbon Cable: step 2, image 2 of 3 AlphaSmart Pro Motherboard Replacement, Detaching Ribbon Cable: step 2, image 3 of 3
      • To remove the ribbon cable, use the spudger to lift each side of the connector from the socket.
      • Gently pull up on the connector to completely remove the connector from the socket.
      • Remove front panel from the motherboard.
      Ask FixBot
    3. AlphaSmart Pro Motherboard Replacement, Prepping Keyboard For Removal: step 3, image 1 of 3 AlphaSmart Pro Motherboard Replacement, Prepping Keyboard For Removal: step 3, image 2 of 3 AlphaSmart Pro Motherboard Replacement, Prepping Keyboard For Removal: step 3, image 3 of 3
      • Use the Phillips #00 Screwdriver to remove the four 1 cm screws from each corner of the keyboard.
      • Gently lift the keyboard from the rear panel.
      • Notice that the keyboard is still connected to the motherboard by two ribbon cables.
      Ask FixBot
    4. AlphaSmart Pro Motherboard Replacement, Detaching keyboard Ribbon Cables: step 4, image 1 of 3 AlphaSmart Pro Motherboard Replacement, Detaching keyboard Ribbon Cables: step 4, image 2 of 3 AlphaSmart Pro Motherboard Replacement, Detaching keyboard Ribbon Cables: step 4, image 3 of 3
      • To remove the ribbon cable, gently pull the connector in the direction of the ribbon cable.
      • Pull the ribbon cable to remove it from the connector.
      • Repeat the exact steps above for the other ribbon cable.
      • While the large connector on the left must be pulled toward you in order to remove the ribbon cable, the smaller connector on the right must be pushed away from you.
      Ask FixBot
    5. AlphaSmart Pro Motherboard Replacement: step 5, image 1 of 1
      • Remove keyboard from motherboard.
      Ask FixBot
    1. AlphaSmart Pro Motherboard Replacement, Disconnecting Battery Prongs From Battery Compartment: step 6, image 1 of 2 AlphaSmart Pro Motherboard Replacement, Disconnecting Battery Prongs From Battery Compartment: step 6, image 2 of 2
      • Flip the AlphaSmart Pro over so that the rear panel is facing upward.
      • Using a spludger, carefully disconnect the battery prongs, located in the battery compartment.
      Ask FixBot
    2. AlphaSmart Pro Motherboard Replacement, Separating Motherboard From Rear Panel.: step 7, image 1 of 2 AlphaSmart Pro Motherboard Replacement, Separating Motherboard From Rear Panel.: step 7, image 2 of 2
      • Using a Phillips #00 Screwdriver, remove the four 0.8 cm screws from the motherboard.
      • Carefully lift the motherboard away from the rear panel.
      Ask FixBot
Author
with
Ashley Orr
142 Reputation
2 Guides authored
Clemson, Team 1-1, Benson Fall 2014 Member of Clemson, Team 1-1, Benson Fall 2014
CLEM-BENSON-F14S1G1
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 92
All Time: 1,180
